Re: New Guy In Arizona
Thanks mechanicalman! They swapped the rear axel out to a 5 lug, the 6 lug was still in the bed of the truck when I got it.
#2 | |
"1971 was the first year for AM/FM radios factory installed. Finally, the front brakes on all light-duty trucks were switched from drum brakes to disc brakes, resulting in much less brake fade under heavy use. While many prior C/K half-ton trucks had used a six-lug bolt pattern (6 x 5.5") for the wheels, two-wheel-drive models switched to a five-lug pattern (5 x 5–inch bolt circle) common to Buick, Oldsmobile, Pontiac, and Cadillac passenger cars. The 1/2 ton 4 x 4 retained the 6 lug bolt pattern". http://en.wikipedia.org/wiki/Chevrolet_C/K That truck should have already been 5 lug with disc brakes. Are you sure those are dropped spindles, not lowering springs? If it has original paint, there may be some semblance of the disc brake decal on the tailgate. |
I was talking about the second truck, the 70 short bed. The long bed is a 71 it came with disc and 5 lug. The 70 somebody swapped in 5 lug front and rear and put disc up front. The original 6 lug rear axel were sitting in the bed of the 70 when I bought it.
#4 | |
![]() ![]() OK. If the 70 front engine cross-member appears to have some bolts from the cross-member to the frame that either have never been installed or have had to have the holes elongated, it may be 73 and up cross-member, 73 and up has 62.7" track width (I've heard it's wider than 71-72). I cannot confirm 71-71 front track width at this time, but I have a 73 up and a 72 but don't know when I will have all those measurements. HERE'S A LINK I KNOW YOU WILL LIKE http://67-72chevytrucks.com/vboard/s...68&postcount=4 Another with useful info http://67-72chevytrucks.com/vboard/s...d.php?t=367260 OK man here's the info on the swap meets: http://www.justsellitautomotiveswapmeet.com/ We need to get together and see who has a nice flatbed trailer (that guy gets in for free) so we all load up a proportionate amount of stuff to sell and split the costs of the space. We take turns watching the store and cruising the meet. Or we could just go to a meet then decide later if we want to rent a spot at the next one, as you can see they have a lot of dates. I'm sending you a PM with my e-mail address so we can coordinate a get-together. My wife loves to get me out of the house on the weekends! Don't know what's going on there, always beer missing when I get home....LOL |
#5 | |
#6 | |
