Old 03-14-2015, 07:14 PM   #1
DANTIP
DANTIP's Avatar
Heater control valve location
I have a '71 big-block A/C truck with new inner fenders and want help properly locating the heater control valve. Does anyone have good photos or dimensions of where this is located. I have photos that give me an idea, but I'm hoping for better info.
Dan
DANTIP is offline   Reply With Quote
Old 03-14-2015, 07:32 PM   #2
Steve Hafner
Steve Hafner's Avatar
Re: Heater control valve location
This was said to be a 71 . . . hope it helps !!!
Steve Hafner is offline   Reply With Quote
Old 03-14-2015, 09:05 PM   #3
Andy4639
Old member
Andy4639's Avatar
Talking Re: Heater control valve location
You can barely see it under the other hose. Should be on passenger side fender. Has a vacuum hose hooked to it and screwed into the fender well.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-14-2015, 09:12 PM   #4
JimKshortstep4x4
Some fenders have the dimples in them for the valve. Here is another picture.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-14-2015, 09:20 PM   #5
Joesjunk
Joesjunk's Avatar
I can look at my '72 big block tomorrow and get a pic.
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 03-14-2015, 10:53 PM   #6
71 super
71 super's Avatar
Dan the first picture is of my bb truck and the valve is located at the dimple on the nos inner fender.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 03-15-2015, 09:46 AM   #7
Andy4639
Old member
Andy4639's Avatar
Big block, small block the fender is the same. The mounting is the same spot no matter. Mine went where I put it wasn't worried about factory correctness. If you have the dimples then that's where it goes if not just put it in at a spot you like as I did. Well I guess if you can get some one to measure for you that would work also!
Old 03-21-2015, 08:34 PM   #8
Joesjunk
Joesjunk's Avatar
Dan, here is my original big block truck. Looks like they missed the dimple from the factory, you can see it in the picture
Old 03-21-2015, 10:35 PM   #9
davischevy
davischevy's Avatar
Joesjunk, what is that sheathed wire that runs parallel to the heater hoses?
Thanks,
Larry
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 03-22-2015, 02:17 PM   #10
cleanfreak
cleanfreak's Avatar
Just took a rusty inner out of a 70 with the valve , can take a good pic if you still need it
cleanfreak is offline   Reply With Quote
Old 03-22-2015, 02:32 PM   #11
leddzepp
Moderator
leddzepp's Avatar
Thanks,
Larry
A/C harness, plugs into the compressor.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
