Old 03-22-2015, 07:37 PM   #1
kerls72
finished truck today but drop is a little off help
So I drooped truck 4/6
wheels 20/22 Coys
72 BB Cheyenne
when you look at front it leans a little to left
is it possible that my shock blew out today?
Or what would cause this?
thanks kerley
kerls72 is offline   Reply With Quote
Old 03-22-2015, 07:48 PM   #2
Carmen Black
Carmen Black's Avatar
Re: finished truck today but drop is a little off help
I would just double check everything. If it looks good, you could just be another victim of "Chevy Lean". Google "Chevy Lean" and see if that is what you have. I am a victim of Chevy lean on a entire brand new suspension rebuild as well.
Carmen Black is offline   Reply With Quote
Old 03-22-2015, 07:52 PM   #3
kerls72
I did hotchkis springs and belltech shocks
so I spent no expenses with good parts
Old 03-22-2015, 08:20 PM   #4
Carmen Black
I don't think Chevy Lean is suspension related, but no one really knows. You have to specifically address the lean to fix it. You probably had it before, but didn't notice until you focused on the suspension.
Old 03-22-2015, 08:37 PM   #5
CST10
CST10's Avatar
Make sure the front springs are seated in the control arms properly.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 03-22-2015, 09:05 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
.... There are pockets in the lower A arms for the springs to set in. Make sure the ends of the coils are seated in the pockets.
LockDoc
Leon
Old 03-23-2015, 06:06 AM   #7
hamjet
hamjet's Avatar
"""is it possible that my shock blew out today?""" Unless shocks are gas filled or the old type that had coil springs around them they serve no lifting pressure. even gas filled I couldn't immagine they wouldn't have enough pressure to lift that much weight. I think the guys are right, check your perches..
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 03-23-2015, 11:39 AM   #8
jhwkns
Registered Cruiser
jhwkns's Avatar
"Chevy lean"is usually a bent frame.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 03-23-2015, 12:10 PM   #9
67ChevyRedneck
67ChevyRedneck's Avatar
I'd park it on a flat level surface and bust out a measuring tape before trying to guess whether or not there is an issue.
It also takes a little time and some driving for the springs to settle to their final ride height.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-23-2015, 04:54 PM   #10
Bagd72Chevy
C10 Collector
Bagd72Chevy's Avatar
Disagree. Usually Chevy lean is from the driver, gas tank, and battery being placed on the drivers side. On a 67-72 though the battery is on passenger side and tank is equally split on both sides, even if relocated to the rear.
PO: How much is it leaning? I would drive it a bit and it will settle some. Do you have a sway bar? Is it adjusted evenly?
///Ryan
1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors
1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10
1967 Chevy LWB- 454 and patina
1971 Blazer - Rusty
1968 Crewcab project
Bagd72Chevy is offline   Reply With Quote
Old 03-23-2015, 05:21 PM   #11
markmdz
can you park it on level ground and take pics straight on from the front and rear? ...and as 67redneck suggested, bust out the tape measure and measure from the ground to the fender well to make sure it's not just an optical illusion.
That said, let's get technical for a half-second. Damn near all manufacturers of aftermarket springs for 'lowering kits' batch test their springs only, so the likelihood of a slight variation from one spring to the next is pretty good (unfortunately). In racing applications, each and every spring is tested on a dyno for spring rate, uncompressed height, compressed height, 'loaded' height, etc.
Nearly no aftermarket mfg's will take corner weight measurements on vehicles and slightly tweak each 'set' to accommodate corner weight differences from right to left on the front and the back. They usually will take a stock spring (1 front and 1 rear) from a vehicle, test it's spring rate (or do rough calculations based on material, height, steel diameter, overall diameter, spring shape (beehive, cylinder, etc) coil spacing, number of coils, progressive or linear, etc) and do a best effort match to accomplish a "x-inch drop".
markmdz is offline   Reply With Quote
Old 03-23-2015, 08:15 PM   #12
kerls72
here is a pic it leans to passenger side I tried to correct photo with leaning my phone yesterday.
I checked spring seat on the leaning side yesterday and made sure it was locked in the correct position.
Old 03-23-2015, 08:18 PM   #13
kerls72
back is nice and level
Old 03-23-2015, 08:20 PM   #14
kerls72
Shocks are Belltech gas shocks
Found a few sites that showed different drops for rating
Max was 4 inches
being a big block I would guess it went down an extra 1/2
Old 03-23-2015, 08:56 PM   #15
LockDoc
LockDoc's Avatar
The side that is down isn't the side that would be out of place it would be the drivers (high) side.
LockDoc
Leon
Old 03-24-2015, 07:42 AM   #16
ksshane
ksshane's Avatar
When I did mine I had a bit of lean as well. I checked everything out to make sure it was seated properly... or at least I thought I did. About a week later I was turning a corner and my front end made a loud pop noise.
I pulled over low and behold my lean was practically gone (Less than a half inch from side to side).
So you might just try driving it a little bit to make sure everything is seated properly. Some times those springs need to move just a little more.
Hopefully you haven't done your alignment already like I did.... Or you will have to do it again if something does move.
71 swb 350/4sp manual 5/7 static drop
ksshane is offline   Reply With Quote
Old 03-24-2015, 09:45 AM   #17
EARNHARDT#3
EARNHARDT#3's Avatar
I think it's cool...just looks like a clapped out ole Chevy! The way we like em :-)
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 03-24-2015, 09:59 AM   #18
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
When you measure the clearance, it's important to have the truck on level ground, which sometimes isn't so easy to find. Also make sure its a good surface. Concrete or paved. Take it to a level parking lot if you need to. When I installed my skyjacker lift kit on my 71 K10 I took measurements before and after the install. After the install, I rocked the truck up and down several times, on both the front and rear to work the new springs and shocks. Granted now, this is a 4X4. I took measurements again, using the same level location in order to have good comparative results. I measured from ground surface to fender and tire to fender. You can see what I did by looking at post #24: http://67-72chevytrucks.com/vboard/s...d.php?t=620627
The drop looks good. What are the details on your wheels and tires? I know they are 20 & 22" Coys, but what are your tire sizes and backspace for the wheels. Thanks.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 03-24-2015, 10:07 AM   #19
Jobe72
Jobe72's Avatar
can't help, but truck looks good!
1972 GMC Sierra LWB (Aquafresh)
1962 Cadillac Convertible
1962 Cadillac Sedan project
Jobe72 is offline   Reply With Quote
Old 03-24-2015, 11:31 AM   #20
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
You could measure it if you really want to know.
When bare of front clip, cab, bed, and without any driveline (except the rear end), my frame was "spec'd" before and after
a full frame off suspension treatment. Then, after the build, the height was 1/4" off side-to-side ...maybe a little more.
After an alignment and driving it a couple of thousand miles, I don't see the lean any more.
Maybe it's not there. Maybe I just don't see it.
Unless you have a lean like this, I'd drive it for a while just to see what "settles".
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 03-24-2015, 12:36 PM   #21
jhwkns
Registered Cruiser
jhwkns's Avatar
Why is it hard to accept that a truck that has been running around for nearly half a century, all the while being grossly overloaded at times, smacking curbs, catching air. Might have a bent chassis. I recommend to anybody with one of these trucks to take it to a frame shop. People will spend thousands on their project, and ignore inexpensive things that will actually make their baby drive properly.
Old 03-24-2015, 09:48 PM   #22
kerls72
thanks for the help so far
I have put a ton of time in the truck with my son and call it OCD or 20 years in the Marine Corps
I want everything perfect.
that pic is funny
