Old 02-04-2004, 07:05 PM   #1
rn2fine
rn2fine's Avatar
Head Bolts / Re-Use or New ????
Built up a 350 recently. Have coolant leak and need to replace head gaskets. The ARP head bolts are less than a few months old. Can I re-use them or should I purchase new headbolts when changing head gaskets?
72 C10 Burb 350 700R4
70 C20 LWB 350 Crate TH400
68 Chevelle
rn2fine is offline   Reply With Quote
Old 02-04-2004, 07:07 PM   #2
flyin99
creator of kong
flyin99's Avatar
They should be fine..........I have done that many times............especially with ARP's..............Brad
flyin99 is offline   Reply With Quote
Old 02-04-2004, 07:09 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
reuse, with a little sealant on them of course.
The only ones you trash are torque-to-yield bolts, which your small block doesn't use.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 02-04-2004, 07:13 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
IF LESS THAN 6 MOS. OLD OR UP TO 5,000 MILES IS WHAT MY
BUDDY HAS ALWAYS TOLD ME ABOUT REUSING ARP BOLTS. I
AM NOT SAYING HE IS A EXPERT THOUGH. WERE THEY TORK'D
OR JUST USED IN A MOK UP TYPE SITUATION ???
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 02-04-2004, 07:15 PM   #5
rn2fine
rn2fine's Avatar
They were torqued to 65lbs. Approximately 3000 miles on them.
68 Chevelle
Old 02-04-2004, 07:17 PM   #6
rn2fine
rn2fine's Avatar
Also, any recommendations on sealant ?
68 Chevelle
Old 02-04-2004, 07:21 PM   #7
Kid
Kid's Avatar
won't have a problem reusing them, but you should check your heads & deck for flatness, something (seating surface not flat, or faultly gasket) created your coolant leak
Kid is offline   Reply With Quote
Old 02-04-2004, 07:43 PM   #8
Kenneth Brown
Indian head shellac for the bolts. It stops coolant from coming up through the bolt holes and into the valve covers.
Kenneth Brown is offline   Reply With Quote
Old 02-04-2004, 07:55 PM   #9
Dean23
68cst_ss490
Dean23's Avatar
for sealant get loctite liquid teflon sealant nothing works better
Dean
edmonton,canada
a winter wonderland
2005 Chevrolet Avalanche LT
cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers.
http://www.cardomain.com/ride/3090973
Dean23 is offline   Reply With Quote
Old 02-04-2004, 08:07 PM   #10
1972C10
1972C10's Avatar
We never put sealent on any of our headbolts. Never had a leak yet.
1972C10 is offline   Reply With Quote
Old 02-04-2004, 11:01 PM   #11
Tx Firefighter
FWIW...I don't do it all the time either, but they taught me in GM school to always use sealant on any bolt that screws into water, including head bolts.
Old 02-05-2004, 10:12 AM   #12
smokekiki
Mike
smokekiki's Avatar
Using the sealent is good preventive medicene.Probably wouldn't leak without it,but why take the chance.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 02-05-2004, 10:19 AM   #13
smokekiki
Mike
smokekiki's Avatar
Of course,I have also been told not to use sealent on head bolts because of it adding resistance and changing the torque rating.
Old 02-05-2004, 01:09 PM   #14
junkyardjohn
junkyardjohn's Avatar
IT DOESN'T HURT A THING TO REUSE THEM , NO MATTER HOW MANY MILES ARE ON THE AS LONG AS THEY ARE CLEANED (ALL THE OLD SEALANT REMOVED) & NOT DAMAGED. (I USUALLY SOAK THEM OVERNIGHT IN A CAN OF CARB PARTS CLEANER , THEN HIT THEM WITH A SMALL WIRE BRUSH) NEVER HAD A FAILURE. JOHN
(& I ALWAYS PUT SEALANT ON THEM)
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 02-05-2004, 03:15 PM   #15
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
I have reused them many times. It is recommended that the threads going in to the block and the threads on the bolts be very clean prior to putting sealant of some type on them. Run a tap through the holes to get the old sealant out.
67Fleetsidedream is offline   Reply With Quote
Old 02-05-2004, 05:54 PM   #16
mocwon
Keep On Truckin'
mocwon's Avatar
You should be okay reusing the head bolts given the short amount of time they have been on assuming they were new to start with. When building up an engine I never reuse head bolts, rod bolts or main bolts. Bolts fatigue over time and not knowing how many times a bolt has been re-used or the punishment an engine has been through can be risky. New fasteners are cheap insurance. ARP provides a torque chart with many of their fasteners so you can keep track of how many times they have been torqued, what they were torqued to and if you really want to go all out how much stretch each fastener sees.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 02-05-2004, 08:32 PM   #17
kwmech
Absolutely--and clean and flat--- been reusing bolts for 30 years and never had a problem
