Robert Olson Transport
![]() Join Date: Oct 2002
What did you get done 3/22/15 edition
Despite a spring kick in the butt from good old mother nature I got a lot done this week. On the plow beast 79K10 we figured ou why the plow wasn't working correctly as it appears a bolt on the plow linkage snapped not allowing it to be picked up correctly. We then replaced the old worn out carb on her with a new edelbrock 1406 then we finally cut down the old exhaust and put on the new exhaust ( stock Y pipe cat mid pipe muffler and tail pipe)
During the week I scored a new set of inner fencers and Sunday we went to cowtown where I got a used right fender to go with the left one I had from the old plow truck Im getting ready to do the left side rocker and cab corner so once that is all done things will be pretty good for the old plow heap I also went down to the 74 and put the one spring in and the junction block in there so that is one stwp closer to being started How about you all?
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Re: What did you get done 3/22/15 edition
I had a lot going on this weekend but still managed to get some done on the truck. After I put my daughter to bed Friday night I went out and put in a much needed cup holder in front of the seat. this is where I got the idea: http://67-72chevytrucks.com/vboard/s...d.php?t=208408.
Then Sunday I did a little bit of wiring. After reading several threads about the power window relay mod I decided to give it a try for myself. The results are decent, I only got the passenger side done but it is now slightly faster than the driver side which has a new motor. I also had a little mishap, my 31 year old cigarette lighter outlet hasn't been working when I plug my phone charger in so I thought I would replace that. No big deal, right? Well, probably due to my excitement over the idea of having all day to work on the truck uninterupted I forgot to unhook the battery before I pulled the old outlet out and managed to blow the radio fuse(I assume the cigarette lighter and radio must be on the same circuit?). Now for some reason as soon as I turn on the key whether the outlet is plugged in or not the fuse for the radio blows. I hate wiring.
Ben 84 C10 Silverado 14 Silverado Z71 |
I replaced the kickdown cable seal to see if that will get it to stop leaking. Note to self; this is best done with the trans out of the vehicle. It can get pretty frustrating trying to get the cable attached, lined up and the bolt started with trans fluid dripping down and very little working room lol. This all the while laying on your back.
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73 |
Finished installing the headliner trim. Waiting to get the sun visors back & then I can check that stuff off the list. Once that was done, I moved on to getting the door panels painted. Not sure if I'll run them permanently or if I'll get some new panels.
Next up.... the dash & related panels.
![]() Join Date: Oct 2014
Took Big Red out for a spin Sunday afternoon. First time she's been out since last fall. Came back home and replaced the vapor canister finally, I've had it for about a month now.
New valve covers went on today
