Old 03-23-2015, 10:57 PM   #1
$20071k10
$20071k10's Avatar
Steering wheel speed sensor????
My 98 gmc Z71 wanders all over the road I have replaced every thing that has a ball and socket joint on it! The only thing I have not changed is the steering box and still all over the road!!!! Would the steering wheel speed sensor cause this???? Help please
Brian
$20071k10 is offline   Reply With Quote
Old 03-23-2015, 11:34 PM   #2
enaberif
Re: Steering wheel speed sensor????
Speed sensor just adjusts the steering box to be looser at low speeds or tighter at high speeds.
You need to look at your rag joint if its that bad.
enaberif is offline   Reply With Quote
Old 03-24-2015, 07:36 AM   #3
speedygonzales
speedygonzales's Avatar
Agree on rag joint. Mine went to crap and same thing.
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 03-24-2015, 09:31 AM   #4
$20071k10
$20071k10's Avatar
thanks guys will replace that!! My wife drives the truck more than me and she informed me that for a bout a week know when cornering she will experience a momentary loss of stiffness in wheel feedback what would cause this?
Brian
Old 03-24-2015, 09:38 AM   #5
enaberif
Ask your wife if it feels as if the steering wheel has hit ice and seems to have lost control.
If the answer is yes then its the speed sensor on the steering column doing this and its a common fault on the trucks.
Old 03-24-2015, 09:58 AM   #6
$20071k10
$20071k10's Avatar
thank you enaberif were is the best place to get one?
Brian
Old 03-24-2015, 10:09 AM   #7
enaberif
Not sure.. I sold my truck before I replaced mine
Old 03-24-2015, 07:55 PM   #8
Boog
laying low
Boog's Avatar
Most auto parts stores sell these. It's a very common replacement part. Less than $50 the last time I bought one. 30 minute job to replace.
Boog
Old 03-25-2015, 07:49 AM   #9
speedygonzales
Test it by disconnecting it for a while and see what happens. There will not be a SES or a code set for it.
Pride and joy
Old 03-25-2015, 09:10 AM   #10
$20071k10
$20071k10's Avatar
would that not make the steering even looser and harder to control?
Brian
Old 03-25-2015, 10:26 AM   #11
95 S_Trucker
95 S_Trucker's Avatar
No. It will allow full power steering pressure to the steering box at all times. It will work like the 88-96 power steering system when the sensor is unplugged.
95 S_Trucker is offline   Reply With Quote
Old 03-26-2015, 09:57 AM   #12
BigBlocksRule
Mine has been unplugged since I bought it, drives fine, not loose at all.
The idea was to restrict fluid at speeds to prevent over-correcting and roll-over. If mine had been connected, I would have hit a truck that pulled out in front of me about a year ago. I missed him by inches at 80mph, did a few swerves and finally got the Tahoe stopped in the median. Got out, changed shorts and made the rest of the trip fine except for shaking like a bear cub crapping a pine cone for a couple of days.
BigBlocksRule is offline   Reply With Quote
Old 03-30-2015, 08:00 AM   #13
$20071k10
$20071k10's Avatar
Ok so I looked for this speed sensor this week end isn't it suposed to be at the end of the column were the joint for the shaft is? If so I don't think mine has one is this possible? no wires pluged to any thing on the end of the steering shaft.
Brian
Old 03-30-2015, 08:45 AM   #14
95 S_Trucker
Its under the dash. The connector is kind of a pain to get to. There is a 2 wire connector that comes out of the wiring for the multifunction switch. It plugs into that connector.
Old 03-30-2015, 09:04 AM   #15
BigBlocksRule
Or do it the easy way and unplug the connector on the power steering pump!
Old 03-31-2015, 06:17 AM   #16
speedygonzales
That's the one I was referring to.
Pride and joy
