Battery Disconnect Switch Location
I am going to install a battery disconnect switch on the truck. But would like some suggestions or photos of some other disconnect switches that anyone else has installed. I have an 83 C10.
I like the idea of this install http://67-72chevytrucks.com/vboard/s....php?p=3062894 but I don't really have access to it with my grill I have the same exact type of switch, actually bought it from the guy who started that thread at his Napa store here in Idaho. |
Roadside Rebuilder
Re: Battery Disconnect Switch Location
May I ask to why you are installing this?
There're a lot of perfectly good reasons. Just wondering what yours might be? |
At the body shop.
I used one like this.
http://m.summitracing.com/parts/fla-fr1003-2 Thru the roll pan. Rear mounted battery though. But with a push/pull you could go any where wiwith it.
" That didnt make it any newer " " Dont antique the equipment " |
To eliminate battery drain. I don't drive the truck much, in 2014 I maybe put 150 miles on it and I went through a new battery. I purchased a red top optima and don't want to drain it.
Roadside Rebuilder
I understand. I used a similar set-up on my old Suburban when I couldn't find the short that was draining my battery.
Once I located the short, I installed it in an odd location under my seat, in the hopes of foiling thieves. |
Here is where I ended up installing the disconnect switch. Thought I would share and maybe give someone else an idea
On place between the sill plate and side seat. Use the ground side Run it to switch then ground to frame right there. Be aware Working on Heavy equipment for decades I cant tell you how many cables had to hook to 1 post because the switch failed. I would put a trickle charger on it.
83 c10 long Box Daily Driver 90 Jimmy parked 98 Road King/ 06 Road Glide In memorium 63 impala SS/ 65 Chevy Panel 65 GMC Short Box/ 68 Camero |
A easy one to use
yeller
I put mine behind my rear place, under a flip up/down GM license plate bracket (one that stays up or down when fully opened. If going to the track, you just flip the plate up, switch is exposed in case something happens and you need to turn off the power. With the plate down, you never know its there. 73-87 cab mount door bumpers were attached on the bottom side of the bumper plate, keeping the license plate from rattling when driving.
EDIT: My battery was relocated under the bed, you need a disconnect switch to pass inspection if taking the truck down the track.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
This is only going to be a bandaid solution. You need to figure out what is killing you battery and fix that.
I've had vehicle sit longer than a month and still be able to start it. |
When truck goes in for paint a painless will be ran. Even after the disconnect will still be used
I had my 77 re-wired over the winter and used a EZ wire 21 circuit harness that I got off Fleabay for way less than a painless. The guy that wired my truck recommended it. He said it's very easy to install.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint "Cool ain't ever cheap and cheap ain't ever cool" |
| Bookmarks |
