Old 03-24-2015, 11:27 PM   #1
NTIMID8R
NTIMID8R's Avatar
Can someone identify this part:
It's on the left hand side next to radiator. Has a vac. line going to it but it's not connected to anything. No wires to it either. Sorry for the crappy cell phone pics. Thanks
Yesterday is history, tomorrow is a mystery, today is a gift, that's why it's called "the present".
1971 Sierra Grande LWB, 350/TH350, Factory Air Lots, of future mods planned!!
NTIMID8R is offline   Reply With Quote
Old 03-24-2015, 11:28 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Can someone identify this part:
Looks like an aftermarket cruise control module
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 03-24-2015, 11:49 PM   #3
NTIMID8R
NTIMID8R's Avatar
I thought it was part of a cruise control but there is nothing else to go with it. It has a knob on it that turns but has no tension and looks like there is an adjuster screw with a jam nut on the other side.
Thanks for the reply.
Old 03-25-2015, 01:07 PM   #4
Livrat
Member #1049
Livrat's Avatar
I do believe it is a vacuum driven air compressor which was used in the AC Delco "pleasure lift" air shock system
Livrat is offline   Reply With Quote
Old 03-25-2015, 02:49 PM   #5
NTIMID8R
NTIMID8R's Avatar
Thanks for the responses guys. I am going to remove it and see if I can find a part number on it then do a search and see what happens.
Old 03-25-2015, 04:19 PM   #6
Andy4639
Old member
Andy4639's Avatar
Wink Re: Can someone identify this part:
That was a factory option vacum pump that would pump up air shocks off the motor vacuum. I have mine installed on the 71.
Here is a link for it. Has all the info you need.
http://67-72chevytrucks.com/vboard/s...d.php?t=559816
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-25-2015, 05:32 PM   #7
NTIMID8R
NTIMID8R's Avatar
Wow! Thanks Andy.
Odd thing is I only have that piece and the air shocks and they are junk. The SPID doesn't show that as an option either. Beginning to wonder what my truck really is!!
Old 03-25-2015, 06:49 PM   #8
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Can someone identify this part:
Originally Posted by NTIMID8R View Post
Wow! Thanks Andy.
I'm not sure if they where for trucks. I know for the cars they where. I have mine off now and use the gauge for the air bags out back. I modified the gauge and put a momentary switch on it to run the air compressor. I have the vacuum pump in a box in the garage.
