Old 03-25-2015, 05:41 PM   #1
rustyescott
rustyescott's Avatar
fuel guage problem
ok folks here is what i've got 1987 c10 swb single fuel tank. fuel guage does not read right , runs out of fuel at half a tank .did this with old sending unit still does this with a new sending unit. guage oms out correct. does this with every fuel guage i use. what do i check now.
rustyescott is offline   Reply With Quote
Old 03-25-2015, 08:38 PM   #2
Liberty
Liberty's Avatar
Re: fuel guage problem
Probably the sending unit is getting stuck.
Liberty is offline   Reply With Quote
Old 03-25-2015, 10:50 PM   #3
rustyescott
new sending unit
Old 03-25-2015, 10:56 PM   #4
midnight rambler
midnight rambler's Avatar
Hows the ground look
midnight rambler is offline   Reply With Quote
Old 03-26-2015, 12:07 AM   #5
tucsonjwt
Have you tried a brand new gauge or a used one? I don't know of anything involved except sending unit, ground, gauge and the wiring in between (unless dual tanks.) My gauge read the same way and a new gauge fixed the problem. If you used an aftermarket sending unit I would suspect that also.
tucsonjwt is offline   Reply With Quote
Old 03-26-2015, 08:53 AM   #6
rustyescott
i've got 10 plus fuel guages , does this with every one of them . did this with old fuel sender , still does this wite new fule sender . spectra brand sender.
Old 03-26-2015, 08:56 AM   #7
enaberif
You need to be checking your grounds.
enaberif is offline   Reply With Quote
Old 03-26-2015, 10:05 AM   #8
hatzie
Moderator
hatzie's Avatar
The gauge has a ceramic calibration resistor on the back of the gauge coil cannister. If it's cracked or not making good contact it'll cause the gauge to malfunction the way you describe.
If the gauge itself has stared to fail that'll cause this too.
The other thing that'll do this is increased resistance in the sender circuit... but that'll cause the needle to read super high, past the Full line on the face, when you fill it.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
