Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 12-28-2014, 11:24 PM   #1
1960chevypanel
FS: NOS GMC hub caps
I'll probably end up needing these a week after I sell them, but I have six NOS 1962-1963 GMC 1/2 ton hubcaps for clip-style wheels. Zero dents/dings, just some rubbing/shelf wear. $150 each plus postage.
1960chevypanel is offline   Reply With Quote
Old 01-15-2015, 04:36 PM   #2
1960chevypanel
Re: FS: NOS GMC hub caps
Bump, $125 each if you get 4 or more. Hard to find NOS parts.
Old 01-18-2015, 10:46 PM   #3
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Wow and I'm Out Of work
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 03-27-2015, 02:04 AM   #4
1960chevypanel
Top
Old 03-27-2015, 12:08 PM   #5
newbe351
Not being a hub-cap/wheel guru, these will not fit the later rims that will clear disc brakes, right? If so, I may be in for four....
newbe351 is offline   Reply With Quote
Old 03-27-2015, 01:27 PM   #6
1960chevypanel
Can you post a pic of your wheels?
Do they have clips around the hub?
Old 03-27-2015, 01:57 PM   #7
newbe351
I don't have stock wheels (yet), running Centerlines. I'm thinking about getting a set of stock wheels and running with white walls, but I have disc brakes up front that I need to clear. From what I remember, the only wheels that clear disc brakes are the later rims?
Old 03-27-2015, 01:58 PM   #8
newbe351
It won't let me edit last post: I have a '66 GMC.....
Old 03-27-2015, 02:25 PM   #9
1963c-10
1963c-10's Avatar
If they are the 4 bump style 6 lug rim they will work. These are the 73 4 bump 4wd rims pictured. Cleared my disk brakes no problem
1964 Short bed trailer
Old 03-27-2015, 04:11 PM   #10
newbe351
That's what I seem to recall from the Fourm. So the 62 - 63 clip stiyle rims will not work. Too bad, these don't come up very often.....
Old 03-27-2015, 11:56 PM   #11
1960chevypanel
So does anyone know if there are any clip-style wheels that will clear disk brakes?
Old 03-28-2015, 06:37 AM   #12
No, not factory. There aren't because no disc brakes ever came on anything when clip-type wheels were used. If a hubcap uses outer nubs, it will fit either drum brake or disc brake wheels. It's the wheels that need to clear calipers, not the hubcap. 3 or 4 nub does not matter with hubcaps. Any 5 or 6-lug GM nub-type wheel will accept any car or 1/2t truck hubcap that uses nubs to mount.
That said, I believe I have seen some wheel company today building wheels that fit disc brakes that use clip-mount for older GMs. I wish I could recall who it was
Old 03-29-2015, 02:22 AM   #13
1960chevypanel
True, clip rims and disc brakes are from two different eras... But even though they weren't designed with disk brakes in mind, I still wonder if there are OEM clip rims that would work with disks. Something has to fit over rotors... Maybe the six lug 16" or even 17.5" clip rims? I bet someone here on the forum is running them.
Old 03-29-2015, 09:07 AM   #14
jdl71
jdl71's Avatar
Somewhere on here there is also a thread about adding clips to nub style wheels.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
