Old 03-27-2015, 05:35 PM   #2
Slammed84
Slammed84's Avatar
Re: Help on lowering
Depending on how you want the truck to sit you can leave it alone, raise the shackles to the 1" drop holes, or put stock shackles back on.
Flip kit & shackles gets pretty low so it will require a C notch for sure.
If you just plan to cut 1 coil the back will be too low with shackles and a flip. Stock shackles will bring the back up to be level with the front.
84' C-10 Custom Deluxe
97' & 98' C-1500 Silverados
Slammed84 is offline   Reply With Quote
