Closed Thread
Old 03-26-2015, 12:20 AM   #1951
Ozzy2013
Ozzy2013's Avatar
Re: What did you do to your truck today? Chapter II
Originally Posted by VWNate1 View Post
Later on I went by NAPA and bought a cart load of engine gaskets and some torque converter bolts for the TH350 .
Am I supposed to use washers on these ? typ ? .
I really need some 6 cylinder parts and Andy in Riverside doesn't answer 'phone calls nor E-mails , who in So. Cal. has a take out engine ? .
I have a couple more pix to post but this junky old computer is so slow it'll choke and lock up instead of down loading them .
Next week I guess .
Yup the flex plate uses washers
Ozzy2013 is offline
Old 03-26-2015, 12:15 PM   #1952
sKnNyPpY
sKnNyPpY's Avatar
Brushed some Calyx on the exhaust manifolds I replaced last year. The rattle can silver header paint spot rusted in about a month in our wet and sticky climate. "Ooh ooh that smell, can't you smell that smell?" Now I need some heat shields so I can clean up the wiring mess!
Size:  54.0 KB Name:  IMG_20150325_170259546_HDR.jpg
Size:  48.4 KB Name:  IMG_20150325_164639641_HDR.jpg
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline
Old 03-26-2015, 01:31 PM   #1953
In The Ten Ring
I called about a front fender since I think I will need one when I remove the radiator core support! So much rust there I think the fender will fall to pieces.
I also stood looking at my truck and decided "if I can stay focused, she can run before fall."
I plan to get back on her beginning in April.
In The Ten Ring is offline
Old 03-26-2015, 05:38 PM   #1954
Blakeman350
Blakeman350's Avatar
Originally Posted by colgad View Post
Nice paint matching doors and dash!
Thanks, just kinda worked out that way
Blakeman350 is offline
Old 03-26-2015, 05:54 PM   #1955
das601
das601's Avatar
Originally Posted by Blakeman350 View Post
I did this stuff over the weekend but my WiFi was down so I couldn't post. I started the build on my 350 it's bored .040 over and has aluminum pro comp heads. Also I swapped out the buckets for a 06 or so tahoe center seat so I can strap in my son's car seat. Now he won't miss out on any cruisin.
Did the seat brackets need a lot of tweaking to fit the floor? I can't really see from your pictures if it is able to move forward or back. Any tips if we try to use a centre seat like you did?
1971 GMC 4x4 4 speed Project
das601 is offline
Old 03-26-2015, 11:35 PM   #1956
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Yesterday I paid for upper and lower moldings, NOS. Wasn't cheap.
Today I bought this. May not be a box, but this is super clean. Looks like there's a small scratch, but I can definitely make this work. Little dab will doer. Looks like the real deal. Better be @$40 w shipping.
Edit: Just spoke to the guy. No box. Bummers......
http://www.oldsobsolete.com/products...y-nos-911311/#
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 03-27-2015, 03:35 AM   #1957
Gravityamp
Gravityamp's Avatar
Originally Posted by Possmguts View Post
looks real sharp... did you do the paint?
Thank you ! Yes I did , I just about got it all buffed out now .
Peace
69 GMC
400/400
2.5/4 drop from ECE
Gravityamp is offline
Old 03-27-2015, 04:36 PM   #1958
Blakeman350
Ya I had to trim a few spots on the frame and had to beat in one spot on the trans hump a little bit. Then I just welded some strap across the front so I could use all the original bolt holes. It doesn't slide forward or backward but the bottoms do flip up and the backs lay forward. I'll try to post some more pics later today.
Old 03-27-2015, 07:39 PM   #1959
Blakeman350
Hope these help
Old 03-27-2015, 11:18 PM   #1960
das601
das601's Avatar
Hope these help
Thanks! Those seats look great in there. I would really want the ability to move them forward and back. I'm sure someone on here has made them work that way.
das601 is offline
Old 03-28-2015, 12:24 AM   #1961
71CHEVYSHORTBED402
Spent another $26 for a service manual. Taught how to read GM instructions for bolt patterns.
Tony
Old 03-28-2015, 06:13 PM   #1962
cooperhw
cooperhw's Avatar
Got the inner/outer fenders bolted back on. Hung the bumper including the heavy push guard. Hung the hood. Ran the front brake lines and hooked up the proportioning valve.
Little more brake/fuel lines and it time to set the short bed box in place.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline
Old 03-28-2015, 08:08 PM   #1963
jrwild
Out with the old, in with the new. Today I installed new front shocks w relocated upper mount points.
http://www.hotchkis.net/product/1963...-front-shocks/
1972 C10 LWB - Sold
1968 C10 SWB - 350/700R4
Jacob, DFW/TX
jrwild is offline
Old 03-29-2015, 02:08 AM   #1964
GoaterAz
GoaterAz's Avatar
Got the truck towed back to the house from the body shop, firewall filled and rust on cab floor repaired.
You remember when drinking too many beers was a bad idea?
Me neither.
GoaterAz is offline
Old 03-29-2015, 11:22 AM   #1965
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today? Chapter II
Finally finished up the engine and tranny re paint , rented a pickup and delivered it to The Paint Jail where my rig is looking very nice indeed .
Engine pix soon , I'm no where near my patch cable right now .
Is there a separate thread for TH350 service ? .
I have a couple Q's about mine .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 03-30-2015, 12:14 AM   #1966
PipsC10
PipsC10's Avatar
Modified stock heater controls for vintage air streamline 4 knob controls
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702
2006 Toyota Tacoma double cab 4x4
PipsC10 is offline
Old 03-30-2015, 11:33 AM   #1967
cooperhw
cooperhw's Avatar
It was yesterday but I ran the brake lines to the rearend. Once that was done I finally got to set the bed on for the first time. Mind you this is the first time I have ever seen this truck with any kind of a bed on it at all except in my minds eye or vision if you will. Been a long three months and still lots to go but at least I can now see that once I widen the bed about 5 inches it will look ok.
This is all phase 1. which is make it a running/driving truck. Phase 2. will probably start as soon as phase 1. is finished.
Later,
Wayne
cooperhw is offline
Old 03-30-2015, 11:37 AM   #1968
WarMonger
WarMonger's Avatar
Where did you get those shocks and relocation kit? That looks good.
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline
Old 03-30-2015, 07:27 PM   #1969
chevy2tom
chevy2tom's Avatar
Knocked some of the winter patina off (washed it lol)
chevy2tom is offline
Old 03-30-2015, 07:31 PM   #1970
VWNate1
VWNate1's Avatar
I dreamed and thought about driving it agin before 2016 as I was doing brake work on my '59 Metropolitan Nash FHC and installed the left front wheel bearings _backwards_ ~ old English cars use ball bearings and you have to install them with the thrust side facing in or you'll have troubles.... (duh) .
I'd cleaned and re packed them with the good Moly grease , installed new brake shoes all 'round , wish I was driving my truck instead .
I had to take it all apart again and knock out the bearings , flip them over and re install , button it all up again .
At least the dogs were happy ~ I usually close up shop earlier .
-Nate
Geezer
VWNate1 is offline
Old 03-30-2015, 07:44 PM   #1971
chip46wis
I painted the white inserts/roof on my 72 cheyenne today!!!
chip46wis is offline
Old 03-30-2015, 08:54 PM   #1972
jrwild
Thanks! Found best price/shipping on Amazon. The install was mostly simple, apart from drilling the hole in top of frame on passengers side, but eventually got it done.
http://amzn.com/B0055ARLUW
1972 C10 LWB - Sold
Jacob, DFW/TX
jrwild is offline
Old 03-31-2015, 01:36 AM   #1973
jrwild
And the work continues..... New tie rods (inner/outer/adjuster sleeve), idler arm, pitman arm, quick ratio steering gearbox and power steering pump.
1972 C10 LWB - Sold
Jacob, DFW/TX
jrwild is offline
Old 03-31-2015, 03:12 PM   #1974
EARNHARDT#3
EARNHARDT#3's Avatar
Today I installed 69-72 tail light bezels on my '67. Considering how rusty my truck is I was pleasantly surprised that all 12 holes drilled were into solid steel.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline
Old 03-31-2015, 10:13 PM   #1975
robertnfrappuls
Drove it 225 miles over the West Virginia mountains...
robertnfrappuls is offline
Closed Thread
