03-28-2015, 03:32 PM | #1 |
Cold starting/running problems
Hey all,
Lately I've been having trouble with my truck in the colder weather. It's always coughed and back fired quite a bid driving it in the really cold weather but it would get by. Lately, I can't even get it started or keep it running in the colder weather. However if it's more than 60 outside or so it seems to start right up and run like a top. It's kind of weird. I am not sure if it's carburation or electrical. I kind of suspect carburation. It's a stock 4b Rochester carb. Any ideas on where I should start or some basic checks?
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
03-28-2015, 04:28 PM | #2 |
Re: Cold starting/running problems
check your choke. do you have an auto choke or a manual?
03-28-2015, 04:39 PM | #3 |
Auto choke. It is closed when cold. It also has stock distributer.
03-28-2015, 05:20 PM | #4 |
stock distributor as in pointsand condenser?? set the points for the proper gap and or dwell
03-28-2015, 07:07 PM | #5 |
Sounds like you have to adjust the choke rod or the vacuum break for the choke.
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
