Old 03-23-2015, 09:51 AM   #651
Rochlow
Re: Project Roxy
So I bought these big fancy brakes from CPP. In trying to adjust them yesterday, I finally got fluid through the lines. However, I couldn't get the caliper to clamp the rotor in the front or rear. I bench bleed the M/C and had fluild coming out of all four calipers.
I noticed that I have a deep bore M/C that CPP provided in the kit and the booster has an adjustment to accomadate the bore.
However, the pedal still goes to the floor and doesn't stop the rotor from spinning.. I'm stumped on this one..
///Relaxed Atmosphere
Rochlow is offline   Reply With Quote
Old 03-23-2015, 10:15 AM   #652
knomadd
knomadd's Avatar
Re: Project Roxy
You may have already looked at all of this, but I'll try to jog your memory or give some ideas where to look...
Are you sure the pedal is contacting the piston in the master? Sometimes there is a spacer required between the pedal pin and the master cylinder to engage them both. I think this might be your problem. It's possible to have the brakes bleed by gravity alone instead of pedal force.
I assume you're using a vacuum booster, but if you are using hydro boost, make sure you've bled your power steering and don't have low fluid or frothy fluid (lots of air in the system).
Are there any obstructions in your master preventing the fluid from leaving the reservoir? Maybe debris in the lines? Did you replace all of your brake lines or reuse factory stuff?
What kind of proportioning valve do you have? Is it a factory style from these trucks, a newer factory style (typical upgrade in most disc kits), an adjustable valve only to the rears? Air can be trapped in a factory style unit. It's possible to bleed some of them, from what I've heard (never done it myself) but I've had air in my lines because of one of those types. At the time, I didn't have many brake tools so I had to have a mechanic pressure bleed my lines to get the last of the air out.
These last items require the pedal to fully engage the master though, which it doesn't sound like is happening.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 03-23-2015, 10:23 AM   #653
Rochlow
Re: Project Roxy
There is an adjustable pin on the booster that is making contact with the bore on the M/C. and I am using a vacuum booster.
All the products are new, including the lines. I'm using a CPP disc/disc proportioning valve that came with the kit.
I was going to do a gravity bleed and let it sit for a few hours, followed by a mechanical bleed.
Old 03-23-2015, 12:16 PM   #654
Hart_Rod
Hart_Rod's Avatar
Re: Project Roxy
Which mastercylinder did you buy?
Hart_Rod is offline   Reply With Quote
Old 03-23-2015, 12:42 PM   #655
Rochlow
Re: Project Roxy
6772FRBK6-BB is the kit from CPP that I bought. It came with a deep bore M/C. However, after reading it appears that deep bore is for manual brakes only and not disc/disc.
Old 03-23-2015, 03:57 PM   #656
knomadd
knomadd's Avatar
Re: Project Roxy
I don't know for sure, but it seems like either you aren't getting full engagement from the pedal to the master or there's still a lot of air in the lines. Even if you booster was bad, you should still have some caliper movement with manual type brakes (just harder since you'd be fighting the booster). The only way I can see the calipers not moving would be due to the pedal and master not engaging completely, too much air in the system, blockage in the lines, or binding in the calipers. Or, the adjustment from the pedal to the booster isn't set correctly (pedal goes to floor before completely engaged with master cylinder).
Maybe I'm missing something, but that's all I can think of. I'll step out now and let someone else chime in.
-Duane
Old 03-23-2015, 04:03 PM   #657
Rochlow
Re: Project Roxy
Yea.. I figure it's one of those four issues.. I just have to hunt to find it. I ruled out blockage because I'm getting fluid to the caliper. However, it's not going threw with alot of pressure.
Old 03-26-2015, 11:00 AM   #658
Hart_Rod
Hart_Rod's Avatar
Re: Project Roxy
Did that kit come with a plastic syringe to help get the air out of the mastercylinder?
Old 03-26-2015, 11:11 AM   #659
Hart_Rod
Hart_Rod's Avatar
Re: Project Roxy
Some helpful articles:
http://www.classicperform.com/Instru...PDF/CP0105.pdf
http://www.classicperform.com/TechBo...oubleshoot.htm
http://www.classicperform.com/TechBook/BrakeBleed.htm
Old 03-26-2015, 04:14 PM   #660
Rochlow
Re: Project Roxy
I did get some emails from CPP on things to try on narrowing the problems down. They suggested plugging the M/C to see if I get pedal. If I don't then, I know I have a booster/M/C issue..
Thanks for the links, Rob. I will give them a read later tonight.
Old 03-28-2015, 09:50 PM   #661
Rochlow
Re: Project Roxy
So I spent the better part of 6 hours trying to get these brakes to work and I'm no farther ahead then I when I started. I gravity bled, vacuum bled and had the wife press the brake while I open/closed the bleeder.
I can't get the rear hose that goes into the caliper to stop leaking. Used different crushable washers and it still leaks. So if fluid is coming out air is getting in.. I'm totally frustrated with this truck at this point...
Old 03-28-2015, 10:37 PM   #662
VA72C10
VA72C10
VA72C10's Avatar
Re: Project Roxy
I understand the frustration. It can ruin your enthusiasm. The brakes on my shop truck build kept me from making it to a meet/show once with similar issues. Came down to a bad master cylinder and air getting in through old/weak rubber lines. Sounds like air is the issue here also at the caliper. Another CPP issue....
Old 03-29-2015, 10:13 AM   #663
jlsanborn
jlsanborn's Avatar
Re: Project Roxy
It's a banjo-bolt connection at the caliper? What's the spotface look like at the port on the caliper? Is the tube hitting the caliper, keeping the hose end from coming down flat on the washers? Photo?
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is online now   Reply With Quote
Old 03-29-2015, 11:45 AM   #664
Rochlow
Re: Project Roxy
It is a banjo bolt and the face on the caliper is not smooth. That's a good possibility that I never thought to check. I will give it a look when I get home.
Old 03-29-2015, 11:53 AM   #665
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Project Roxy
I understand your frustration with CPP parts.
I have made up my mind I will only use Wilwood M/C from now on.
Aluminum body so they won't rust and a Super quality product.
Also check the "free play" at your brake pedal, and make sure it's not excessive.
Keith
Convert to disc brakes.
Old 04-05-2015, 10:09 AM   #666
Rochlow
Re: Project Roxy
Well, I'm beyond my wits end with these brakes. So since it has to go to someone else to have the exhaust and pinion angles done, I'm going to have them fix the brakes too.
Old 04-05-2015, 12:18 PM   #667
JakeDW
JakeDW's Avatar
Re: Project Roxy
I went from a chrome master to a wilwood master made a huge difference also using a wilwood prop valve.
Jake
JakeDW is offline   Reply With Quote
Old 04-07-2015, 10:31 AM   #668
cericd
cericd's Avatar
Re: Project Roxy
The paint is the same formula that GM used for years. One step process, sprayable right out of the can. Great coverage. My only worry is durability.. We will see when I pull it down to put it together.
How did the frame paint hold up?
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 04-07-2015, 09:14 PM   #669
Rochlow
Re: Project Roxy
It's held up a lot better than I expected.
Old 05-22-2015, 05:51 PM   #670
Rochlow
Re: Project Roxy
So I'm trying to figure out the driveline angles currently. My issue is the trans yoke is hitting the cab and the trans angle is already down 6 degrees. However, I had to get engine mounts from Porterbuilt that raised the motor a half inch because the oil pan was hitting the rack and pinion.
Has anyone else ran into this problem running a first generation small block and a th350 trans?
Old 05-22-2015, 09:54 PM   #671
Rochlow
Re: Project Roxy
I really wanted to get this taken care this weekend. Left a phone message and sent emails, there were responses but no resolution.
Old 05-23-2015, 12:15 AM   #672
jmedero
jmedero's Avatar
Re: Project Roxy
Sorry man I know it's frustrating when your trying to wrap stuff up.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 05-23-2015, 02:34 AM   #673
ajgriffin
ajgriffin's Avatar
Re: Project Roxy
cut the cab?
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old 05-23-2015, 07:51 AM   #674
lolife99
lolife99's Avatar
Re: Project Roxy
You have the frame level front to back and the trans is 6 degrees down, and it's hitting the cab?
(or is it setting on the wheels at ride height?)
My Ginger chassis had a first generation Dropmember in it and I was able to get it set at 5 degrees down.
Keith
Old 05-23-2015, 08:23 AM   #675
Hart_Rod
Hart_Rod's Avatar
Re: Project Roxy
Roch - how high was the spacer that you put under the carrier bearing? I had to install a 2 7/8" one in order to get my angles close.
