Old 03-22-2015, 07:15 PM   #1801
blue57
blue57's Avatar
Re: Kabwe's aka Bam's build
Glad to see you back at it. Cant wait to see this one done.
my build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=522711
blue57 is offline   Reply With Quote
Old 03-23-2015, 01:35 PM   #1802
VDOG
Grand PooBaa Member
VDOG's Avatar
Originally Posted by bajabob View Post
Bam
as usual... the bar is high.. you make the rest of us try to play up..... Dam u Kabwe !!!!!
LMAO!!!!!
But BajaBob is right, you do set the bar high. Its all good, just makes the rest of us strive to build our trucks by following your lead. Brothers 2020, heck I think I might be ready by then also.
VDOG is offline   Reply With Quote
Old 03-23-2015, 03:38 PM   #1803
Red Foreman
Red Foreman's Avatar
Frame work looks awesome!
RIP John (Lambis), my beloved Father & best Friend.
My Build 56 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=486721
Red Foreman is offline   Reply With Quote
Old 03-23-2015, 04:39 PM   #1804
hopped up
hopped up's Avatar
Damn Bam ! That is a really sweet setup! Def worth redoing a few things. Good meeting you on Saturday and Choppin it up.
hopped up is offline   Reply With Quote
Old 03-23-2015, 07:18 PM   #1805
Rods57
Rods57's Avatar
That's cool, but now i have to make sure that I keep telling myself "I will not cut mine up again and follow BAM"
Rods57 is offline   Reply With Quote
Old 03-24-2015, 02:21 PM   #1806
Kabwe
Certified Car Nut
Kabwe's Avatar
Thanks guys.
Hopped up it was great to finally meet you. Vdog finally made things right.lol
Kabwe is offline   Reply With Quote
Old 03-26-2015, 05:55 PM   #1807
VDOG
Grand PooBaa Member
VDOG's Avatar
Once again it my fault. Its all good.
Old 03-28-2015, 11:49 PM   #1808
chevyrestoguy
chevyrestoguy's Avatar
Nice work, Bam! I know exactly what you mean about doing something and then tearing it all out later. I've doing it for years!
Don't tell anyone, but I've been working on my '55 for the last few days. The Old Girl needed some love, and I spent the last couple of days going through all my parts and doing an inventory. I've got a game plan, and want to have it at a certain point before Father's Day. Gotta set some goals!
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 03-29-2015, 12:43 AM   #1809
Kabwe
Certified Car Nut
Kabwe's Avatar
Thanks guys,
The set back of installing the x member means I can no longer use the factory brake assembly. So here is my brake bracket I fabricated. As you can see I also had to notch the frame to have clearance for the Hydroboost unit.
I already modified the panel assembly, all that is required is a push rod extension but I think I better wait until the cab is back on to mock it up so that I know the brake is in the right spot.
Old 03-29-2015, 12:48 AM   #1810
hotrod1
56 - autocross
hotrod1's Avatar
Bam is back in business!!!
hotrod1 is offline   Reply With Quote
Old 03-29-2015, 04:17 AM   #1811
RockinKees
RockinKees's Avatar
Tight fit in there!
Looks great!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 03-29-2015, 01:54 PM   #1812
Kim57
Kim57's Avatar
Nice job on that stuff Bam.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 03-29-2015, 03:39 PM   #1813
Dan in Pasadena
Dan in Pasadena's Avatar
"HE'S ALIVE!, HE'S ALIVE!"
Nice restart. I like it, very nicely done. What's next?
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 03-29-2015, 10:17 PM   #1814
boyztoyz66
Great looking truck project. I'm building a 56 stepside shortbox to mount above a newer Yukon or Tahoe 4x4 chassis. I've got a lot of patch panel and dolly work behind me, but still need cab corners, steps, rails, etc.
I just found a 56 car dash and was wondering if ya had any tips or tricks for the swap? I dont have the dash out of the car yet, so Im starting fresh.
thanks, appreciate any advice,
Dave
boyztoyz66 is offline   Reply With Quote
Old 03-30-2015, 01:47 AM   #1815
Kabwe
Certified Car Nut
Kabwe's Avatar
Here is the piece I fabricated for the pedal assembly.
After a lot of measuring here it is tacked in place. I'm going to leave it tacked until the cab is back on the frame, because I may have to move it a little bit.
Here is the pedal installed. Yes the push rod connection clears the bottom tube by about 1/2 inch. As you can see I need to make or purchase a longer push rod extension.
Old 03-30-2015, 08:35 AM   #1816
Kim57
Kim57's Avatar
Nice fab work Bam.
Kim
My build thread
Old 03-30-2015, 09:21 AM   #1817
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Very nice!
ChuckDriver is offline   Reply With Quote
Old 03-30-2015, 09:52 AM   #1818
oldman3
oldman3's Avatar
Looking good...Jim
oldman3 is offline   Reply With Quote
Old 03-30-2015, 11:56 AM   #1819
ptc
ptc's Avatar
You should be able to make it out of thick wall DOM tubing and then just drill it to size and tap it. Im doing the same thing on mine, I have the same unit.
I think Im gonna clevis the Booster end, then tap one side LH thread and one side RH thread on the rod. With RH and LH rod ends this will make it adjustable in place.
lookin good!
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 03-30-2015, 03:22 PM   #1820
Dan in Pasadena
Originally Posted by ptc View Post
.... With RH and LH rod ends this will make it adjustable in place....
Smart!
Old 03-30-2015, 03:23 PM   #1821
VDOG
Grand PooBaa Member
VDOG's Avatar
Some impressive work Bam.
Old 03-30-2015, 04:43 PM   #1822
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work Bam!
Ryan
1969 Chevy milk truck
Old 03-30-2015, 08:21 PM   #1823
Roadkill58
Roadkill58's Avatar
Looking good Bam!
I finally got my chassis sorted out. Mounted the m/c just under front of bed.
Need to make and extension too.
Rust Never Sleeps
Roadkill's 58 Chevy Stepside build
Roadkill's 69 Custom C20
Roadkill58 is offline   Reply With Quote
Old 03-31-2015, 01:50 AM   #1824
Nut Case
Nut Case's Avatar
Mr. Bam you're the man. Your creativity is exceptional. What Hydro-boost are you going to use? New? salvage? Dodge? Chev? I sure hope that truckin gods smile down upon you and you're blessed with time, health, and fundage to keep on truckin. Be safe Chase
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 03-31-2015, 11:38 AM   #1825
Kabwe
Certified Car Nut
Kabwe's Avatar
Thanks for the kind words everyone
My hyrdroboost unit is salvaged. Its from a Chevy Astro Van.
