Old 03-25-2015, 07:29 PM   #1
Chris04
Chris04's Avatar
Need help finding a aftermarket center crossmember!
Hey guys I'm lowering my 70 swb truck pretty low and I want to go with a aftermarket center crossmember so I can run exhaust thru it and also benefit having a larger hoop in center in case I decide to go to a one piece in future but as of now I have a two piece and All I can find is porter built's crossmember that works with a two piece but it requires modifying drive shaft since the carrier mount is moved forward and western chassis advertises one that works with a one or two but when I called to make sure I was told that it only worked with a one for it didn't have a carrier bearing mount! So where can I find one that works with my two piece? I have searched and searched with no luck, and I don't want to keep my stock one of I don't have too , I really want a aftermarket, thanks for any help!
Chris
1972 Cheyenne super
1949 3100
Chris04 is offline   Reply With Quote
Old 03-25-2015, 10:25 PM   #2
UP GRADE
one set closer
UP GRADE's Avatar
Re: Need help finding a aftermarket center crossmember!
Try CCP and BROTHER TRUCKS
UP GRADE is offline   Reply With Quote
Old 03-26-2015, 06:35 AM   #3
Chris04
Chris04's Avatar
I already checked one piece only and it seems brothers sells all cpp parts mostly or at least I know the crossmember was a cpp! Thanks anyway man
1972 Cheyenne super
1949 3100
Old 03-26-2015, 06:40 AM   #4
PGSigns
PGSigns's Avatar
One option would be to customize yours. Two pieces of 4" OD pipe to make your pass throughs for the exhaust and do the flip on your trailing arm brackets.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-26-2015, 11:24 AM   #5
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I also check Early Classics and theirs says for short bed, 1 piece driveshaft. Not sure you'll find an aftermarket one for a 2 piece setup or you would need to modify it.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-26-2015, 12:32 PM   #6
Chris04
Chris04's Avatar
Thanks guys, I really didn't want to modify or cut holes in mine if I didn't have too but may have to do that! I wonder instead of flipping trailing arm mounts if I can just buy the brackets from western chassis and mount them that way I could have different setting options?
1972 Cheyenne super
1949 3100
Old 03-26-2015, 01:56 PM   #7
bs46488
The CPP one can do both LWB and SWB, 1 or 2 piece driveshafts.
Check out this link (just for the picture and wording)
http://www.dreamershotrods.com/cppto...yandgmcpu.aspx
I bought the one from POL.
I'm not 100% happy with the fitment. If I was to re-consider the purchase...I would keep shopping around.
bs46488 is offline   Reply With Quote
Old 03-26-2015, 02:33 PM   #8
Chris04
Chris04's Avatar
Well dang sure enough it says on their website for one or two piece, I could have sworn I read on their ebay listing it was just for a one piece! Thanks for all the help guys I feel stupid now!
Chris
1972 Cheyenne super
1949 3100
Old 03-26-2015, 02:36 PM   #9
PGSigns
PGSigns's Avatar
The one they had on Ebay may have only been for one piece.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 03-29-2015, 10:15 AM   #10
Popcorn W
Popcorn W's Avatar
Jimmy
Sorry to hijack with a stupid question, but can you explain "flip trailing arm brackets" please?
My build thread:
Project Moonshiner Bagged & Z Frame 63
http://67-72chevytrucks.com/vboard/s...d.php?t=659205
"I love the smell of grinding metal"
Popcorn W is offline   Reply With Quote
