Old 03-29-2015, 06:39 PM   #1
East Tex
Advise Before Powder Coating
A question to the guys that powder coated their 4x4 frames.
Did you remove your front spring bushing brackets, and powder coat them separately? Then bolt them back on afterwards? Or just leave them on? Also I'm guessing that I should burn those old bushings out, before taking it to be powder coated. Their ovens go up to 400 or 500 degrees, so that rubber would probably melt out and ooze all over the frame.
My 1972 K5 6.0 LTR 4L60 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=622068
East Tex is offline   Reply With Quote
Old 03-29-2015, 07:43 PM   #2
88fordf150
88fordf150's Avatar
Re: Advise Before Powder Coating
I would remove it so it can be sand blasted behind the bracket too. Bolt back together with some grade 8 bolts AFTER powder coating.
Brad handshoe
88fordf150 is offline   Reply With Quote
Old 03-29-2015, 08:32 PM   #3
Possmguts
Possmguts's Avatar
should be able to pick that apart with a thin flat head and pull it out in little pieces... no need to try and burn it out... that just takes to long and stink like hell... besides, a good powder coat shop wont do it with rubber in the hole anyway
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 03-29-2015, 09:13 PM   #4
70'
70''s Avatar
I just had my frame done. Any brackets that are still solidly attached to the frame with factory rivets leave them alone. You will never get as tight a fit with bolts as those factory rivets provide. Now if you can wiggle the brackets replace them. Bushings will all need to be removed.
70' is offline   Reply With Quote
