CL Denver find, not mine, 64 short box K10
Don't see these very often. Looks to be in decent shape and comes with extra parts. If I was in the market for this, I'd be all over this.
http://denver.craigslist.org/cto/4942292615.html |
Re: CL Denver find, not mine, 64 short box K10
Love the slider and '63 grill!
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
![]() Join Date: Mar 2013
Nice truck!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
![]() Join Date: Feb 2014
Looks nice!
Nice find!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
This will be my first posting on these boards, and it's all because of this here truck. I've been reading the forums on the 60-66 models night and day for the past 3 or 4 days
I've been wanting to get an older model pickup and restore it WHILE I use it as my daily driver. This turned out to be the first truck that really struck my fancy. I've got a few more photos I took with my iPhone: Driver Side View: ![]() Rear View: ![]() Interior Shot: ![]() Cancerous Area Passenger Side (Similar driver side): ![]() Rear Differential: ![]() Underside view of Rocker Panels: ![]() I got a few more photos on my iPhone but they didn't turn out so well. This will be my first vehicle to do major work on. I know she'll be a lot of work, but I wanted to see if there's anything you seasoned vets are seeing that I'm NOT seeing that would be cause for concern. I cold-cranked the 283 no problem, drove her around the block and got up into 2nd gear, but didn't take her much further than that. I shifted through the gears without going into 3 and 4, but 1, 2, and R seemed fine. The 35s will need to replaced immediately. He also has two better condition doors with all the hardware/paneling (a little corner rust) and a new hood. Also, he's asking $5400, but I'm not sure how close to that I want to come. I don't really know how to determine a fair price other than by what I see come across craigslist. What do you guys think about it? Any help would be appreciated! |
![]() Join Date: Oct 2012
Verify it is a factory 4x4 by the VIN. Should start with 4K14. The t-case shifter in the pics leads me to believe it is on a 64 4x4 chassis, but I'd be sure the body matched before I pulled the trigger. Other than that I think he's a bit high. I'd say around 3500-4k would be more realistic, but they also don't come up for sale nearly as often as the 2wd trucks.
Thanks for the response, jdl71.
I did check the VIN, and it did start with the 4K14. This one was built in CA. I just offered him $3600 prior to seeing this, so I'm glad I was estimating it in the same ball park. |
So happy that I found this and someone here bought it, or might buy it. Good luck!
