Old 03-31-2015, 11:39 AM   #1
SayBye
SayBye's Avatar
Going 5 speed, column idea's?
For the guys that have gone to floor shifter, what have you done with where ur column shifter once was? just removed the shifter and left the hole or what?
SayBye is offline   Reply With Quote
Old 03-31-2015, 12:53 PM   #2
PGSigns
PGSigns's Avatar
Re: Going 5 speed, column idea's?
I have the floor shift column in the 66 and on the 63 I just removed the handle and cut off the piece that sticks out of the collar. Was just going to fill the hole with liquid metal and repaint it. Have got a flaming river column for it now.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-31-2015, 01:59 PM   #3
pimpston65
pimpston65's Avatar
switched to a non column shift unit and sold it to a member... if you can find a 4 speed column that would require pulling the column and steering shaft...
pimpston65 is offline   Reply With Quote
Old 03-31-2015, 02:17 PM   #4
TJ's Chevy
TJ's Chevy's Avatar
I've seen alot of guys use the paintable ididit floor shift steering column.
Old 03-31-2015, 10:05 PM   #5
Lugnutz65
Lugnutz65's Avatar
I still have my 3 speed shift collar on the column. I will either cut off the boss that sticks up and finish it off smooth like PGSigns suggested or maybe swap to an Ididit Column if I decide later that I want a tilt SW. I also toyed with the idea of using it as a place to install a 4 way emergency switch or other gadget.
I've heard folks mention how they think it looks "tacky" to just leave it there but I say just do whatever makes you happy. Mine is staying for the time being because I want to spend time on more important things - like getting my truck on the road (legally).
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 04-01-2015, 08:58 AM   #6
1963c-10
1963c-10's Avatar
Get a four speed column delete and problem solved. I have an extra one sitting here in primer I won't be using as I finally found a factory 4 speed column.....PM sent
1964 Short bed trailer
