![]() Join Date: Mar 2004
Re: Question for vortec 06 swap people
Is this a complete engine with all the accessories? I don't understand why they are telling you to get this throttle body and that injector, etc. ???
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
#2 | |
I broke the throttle body electric plug pulling the engine. But everything else is there and still plugged in. I even have the driveshaft and trans xmember and power steering lines just if I can use some of this stuff to fab up with or what ever. I'm looking for the way to do it and It work without having bugs. I know I need a harness. Because there is no way I'm gonna sit and make one again. I did this 1 time before and never again will I do it. I would rather pay $600 for one. However what I don't know is if I should go cable operated TB or fly by wire. And will these stock truck manifolds work before I hang the engine over in there and discover it then and have to set it back down. Fuel cell is what I may be going with. But what fuel pump will work for the engine without using a regulator or starving it or making air bubbles in fuel line?
1965 C10 Project |
