Old 03-31-2015, 08:22 PM   #1
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
I have my axle off...
I got my axle off this past weekend and dropped it off at the shop. I am going from 3.07:1 ratio to 3.73:1. Along with the ratio change they are going to inspect the axel to make sure the bearings and other wear areas are in good shape. It is a 43 year old axel. I was told it will take 2-3 weeks to get it repaired and back to me.
Is there anything else I should inspect or change while I have the axle out? I had it down to the frame about 8 years ago but didn't do anything with the suspension or frame other than coasting it. Anything specific with with the leave springs? I thought about having the driveshaft rebalanced.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 03-31-2015, 08:45 PM   #2
rocknss
rocknss's Avatar
Re: I have my axle off...
I would add a limited slip unit to it.
Steven
69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners
2017 50th Anniversary Camaro SS
2004 Chevy Impala LS
2016 Chevy Malibu LT
rocknss is offline   Reply With Quote
Old 03-31-2015, 08:57 PM   #3
JayDubBlazer
go cyclones
Here is a pic right before I removed it. Also where can I get replacement ubolts?
Wes
PROJECT OLE GREEN
2017 Silverado LT
Old 04-03-2015, 07:41 PM   #4
cla511
cla511's Avatar
You will either have to make some or do as I did and use 73-87 bolts and bracket. They are upside down from what we have but work very well and are much bigger. The plate is a little wider but it is not a big deal.
1972 C10 Cheyenne 402/TH350
1985 GMC 1500 Sierra Classic 350/700R
1986 K20 427/NV4500
1986 K20 Sub 406/TH400
"Life's tough.....It's enough tougher if your stupid." John Wayne
cla511 is offline   Reply With Quote
Old 04-03-2015, 08:02 PM   #5
70'
70''s Avatar
Yep, this a perfect time to go ahead and replace the bushings in the rear leaf springs, as well as the U joints in the rear driveshaft. Your already in there, the hard part of those two jobs is over. You should be able to order new u bolts from Amy suspension place. I would not take to making your own, that's a dangerous game to play. From my own experience, please also make sure the gear shop checks out your spring perches really well as the guide hole can become egged out pretty good over time.
70' is offline   Reply With Quote
Old 04-03-2015, 08:51 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
I would ask the shop that's doing your work where to get the "U" bolts. I had Merrill Axle & Wheel in Des Moines make the ones for my '67 SWB when I put the 2" lowering blocks on it. I think they were 30 bucks.
LockDoc
Leon
Old 04-04-2015, 10:15 AM   #7
JayDubBlazer
go cyclones
LockDoc
Thanks Doc, I took the axle to quick performance here in Ames. I will check into Merrill Axel in DSM.
Wes
PROJECT OLE GREEN
2017 Silverado LT
Old 04-04-2015, 10:22 AM   #8
JayDubBlazer
go cyclones
I also wanted to add a safety note if anyone ever finds this thread again. IMPORTANT: if you need to cut your U-bolts off because you cannot budge the nuts due to rusting, keep in mind that the springs will store energy. I was caught off guard when cutting them off and the bolt broke off when I still had about 1/8" to go and the bolt broke off and bounced off the concrete floor, the springs may look like they do not have a load but as long as the nuts are tight against the leaf springs assume that they are storing energy.
Wes
PROJECT OLE GREEN
2017 Silverado LT
Old 04-04-2015, 05:39 PM   #9
LockDoc
LockDoc's Avatar
It's not so bad if the vehicle is sitting on the ground with all of the weight on it, but if you have it jacked up with stands under it hang onto your hat!!! I made that mistake a long time ago with the cutting torch....
LockDoc
Leon
