Old 03-31-2015, 10:41 AM   #1
Lugnutz65
Lugnutz65's Avatar
Best way to remove vent glass from frame?
I was cleaning, inspecting and lubricating my 1965 door vent assembly when KaaBAAAAM the glass slid out of the frame and smashed on the ground. I have an extra vent glass, but of course I can't get it out of the frame for fear of damaging the whole frame and vent assembly.
Any tips on how to remove just the glass? It's just set in the frame with glass setting tape, right?
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 03-31-2015, 12:39 PM   #2
61K10
61K10's Avatar
Re: Best way to remove vent glass from frame?
block of wood with a sq edge set against the frame and tap with a hammer. spray some wd-40 also. thats how i did mine. be careful with the hammer lol!
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 03-31-2015, 09:38 PM   #3
Lugnutz65
Lugnutz65's Avatar
Thanks! Your tip gave me another idea. Sounds like you tapped the frame using a wood block as a tamp. You must have held the glass with your hand or something like that.
I tried another idea that came to mind. Here it is. Instead of the brass punch I could have (should have) used a block of wood.
Thanks!
Old 04-01-2015, 09:02 AM   #4
1963c-10
1963c-10's Avatar
I think I heard it mentioned before about soaking in diesel to loosen up the stuff holding them in.....think its actually in the 63 shop book.
1964 Short bed trailer
