![]() Join Date: Oct 2008
Help with Installing Upper and Lower Trim
So -- my '72 Custom/10 SWB came equipped with upper and lower trim moldings options... but the prior owner removed it and filled all the holes when he had the truck repainted.
I am looking to put the moldings back on, here are my questions -- 1) Has anyone had really good results using the clips with adhesive? (LMC sells these...) 2) If I decide to go with the original type clips and not the adhesive, can I install the molding properly without removing the fenders and bedsides??? Thanks for the info!! |
![]() Join Date: Jan 2002
Re: Help with Installing Upper and Lower Trim
I'm not going to be a huge help here but order mar-k trim. It is second to none hands down
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
Prestige Worldwide
![]() Join Date: Feb 2001
I recently replaced all of the moldings on my son's 71 GMC. We used mostly parts from LMC and a few NOS pieces.
No, I don't like the adhesive clips because the molding doesn't fit as flush up against the body as they do when using spring type clips. Yes, you can install the moldings without removing the fenders and bedsides.
"Negative people always seem to have a problem for every solution" |
#5 | |
Still Learning
This is just my personal preference though. 2.) Yes and no. You can properly drill all the holes for the trim retainers. But you wont be able to reach all the nuts on the rear in some spots. i.e. the lower trim on front of the doors (ask me how I know). I was able to get it done but I spent literally an hour on 1 nut on the driver side. On the passenger side I just pulled the door. It seems like there are some spots on the fenders that will be a problem too, I know you need access to the emblem bolts too. Many of the OEM clips are just push in retainers. |
![]() Join Date: Dec 2013
I used the adhesive clips but pulled off the tape and used .03 thick black adhesive tape order from McMaster Carr. Sticks much better and closer to the panel.
![]() Join Date: Oct 2009
ledzepp gave me some great advice - I used 3M double-sided trim adhesive instead of the stuff that came with the adhesive clips. Worked better. I believe it also allowed for a less pinched look because it bumped out a bit. Different from others' experience it sounds like.
#9 | |
Still Learning
I wonder if it's possible to use just the tape -- no clips -- so it is more flush against the body panels??????????
