Old 03-30-2015, 05:33 PM   #1
afrance
Dana 60 rear hub
My son and I are restoring a 69 C20 and I finally found a Dana axle for it that we planned to use the 3.54 r&p to lower the rpms. Unfortunately after tearing it down we found one of the inner races had spun and is .020 too large. I know there is one loctite product that maxes at .020 but would prefer to replace the hub. Since I have been unable to find any does anyone know if any other d60 hubs will work on this axle? 94-97 dodge 2500, e350?
Thanks,
Alan
afrance is offline   Reply With Quote
Old 03-31-2015, 09:37 PM   #2
Mike C
Mike C's Avatar
Re: Dana 60 rear hub
Have you tried the HO52 hub? Or possibly even a 14 bolt? There was a lot of sharing of parts and I know the Dana 70 and the 14 bolt can use the same, just make sure SRW donor.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-31-2015, 10:25 PM   #3
afrance
I actually hadn't thought about trying the HO52 hub, I do have that on the truck now so I can try that and see. My brain was stuck on finding another D60 hub
I don't have any 14 bolt axles to try but I'll search around and see if anyone has done that on the rear hubs.
Thank you Mike
Old 04-01-2015, 06:08 PM   #4
afrance
I may have found a 71-72 hub but it has a "fluted" or splined center instead of the smooth one I have on the 69. Can anyone confirm if the 71-72 hubs looked like this? Let's see if the picture shows.
http://67-72chevytrucks.com/gallery/...hp?photo=41358
Old 04-01-2015, 06:21 PM   #5
bluek5
bluek5's Avatar
What size are the studs? 71-72 should be 9/16. I will go pop my hubcap off in a while and look at mine.
Paul
bluek5 is offline   Reply With Quote
Old 04-01-2015, 08:39 PM   #6
bluek5
bluek5's Avatar
Here is a picture of a 71-72 hub I installed on a 69 or 70 rear end.
Old 04-01-2015, 09:19 PM   #7
afrance
Thank you Paul! I appreciate you posting the picture. That definitely shows me the difference in the hubs.
Apparently 70 and earlier D60 hubs are smooth
Name:  69 D60 Hub.jpg
And 71-72 are not
