Re: Lowering Questions
Yes. All the rear relocation kit does is change the angle of the rear shock so that it will perform better with the drop. Very easy to put in. All you have to do is air hammer out the rivets for the current brackets and then bolt in the new. You will still need the drop shock because the gap regardless of angle is smaller than that of stock height.
Thanks, Casey ![]() The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045 The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699 |
