04-02-2015, 07:46 PM | #1 |
Door panel mounting problems.
So I'll start by saying that I used the search function with every combination of words that I could think of with squat for results. Just in case this is a really obvious issue that been talked about a couple dozen times already.
I'm getting ready to rebuild the innards of the door (felts, rubbers, etc) I noticed a few screws missing from the door panels, but now that I've got the panel off I see that the PO managed to strip the heads off of four of the screws and totally knock the square nut out of one hole. Anybody ever deal with this? |
04-02-2015, 08:05 PM | #2 |
1961 crewcab
Re: Door panel mounting problems.
yes, on one truck I just didn't install the screw, but its a work truck!
on the other I welded a nut in the hole. the 4 that are stripped , you may have to drill them out. on one truck I was able to weld a nut to the stripped part of the screw, and then unscrew it that way.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
04-02-2015, 08:36 PM | #3 |
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
I had a similar problem.
I didn't have the attachment screws so I bought a new set from Totally Stainless! One of the nuts were missing though, so I glued it back on using an automotive epoxy for fixing bumpers, and when it started to get hard enough to stay in place, I screwed the door panel onto the door to improve position of the nut until the epoxy cured. I have had the door panels off several times since without incident! My doors & door-panels were painted at this point, soI did't want to weld.
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=512904 |
04-02-2015, 10:42 PM | #5 | |
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
04-03-2015, 12:16 PM | #6 |
Yep, I had to weld a couple nuts back into place on my driverside door. It isn't uncommon.
