how do i find out what size rear is in my truck
Hi all i have a 1995 2500 chevy 4x4 pick up, is there a way to tell what rear i have? thanks!
Re: how do i find out what size rear is in my truck
6 lug or 8 lug? 6 lug will be 14 bolt semi float, 8 lug could be 14 bolt semi float or a full floater....
2000 Chevy Tahoe Limited 3/5" drop 2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon stock SAS 6" |
![]() Join Date: Nov 2003
If your question is gears you can get really close by jacking it up and turning the tire and counting the driveshaft revolutions. Put the truck in neutral and block your tires. If it's an open rearend jack it up enough to get one tire off the ground. If it's a posi jack it up enough to get both tires off the ground. Mark the tire and the driveshaft. Turn the tire ten times and count the number of times the driveshaft turns. If the driveshaft turns 30 times you have around a 3.00 gearing (3.08 likely).
If I remember right on an open rearend you need to divide your answer by 2. So to keep it easy turn the tire 20 times, and then you can divide the driveshaft revolutions by 10.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#4 | |
Should be a 14 bolt, look at the bottom right 2 pictures.
Countdown Survivor
If you've got the RPO codes on the SPID sticker inside the glovebox you can tell what came with the truck by decoding that. Should be something that starts with a "G".
93 Yukon 89 Silverado Z71 SWB Sport 91 K 2500 Silverado "Lobuk-Worktruk" A MAN OF HONOR DOES NOT LIE, CHEAT, OR STEAL, NOR TOLERATE THOSE WHO DO. Gettin' old ain't for sissies. |
The codes in the glove box will help you in figuring out the ratio. They will not help in figuring out the size of the differential.
| Bookmarks |
