Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1967-1972 Chevrolet & GMC Pickups Parts Board > Blazer and Suburban Stuff
Old 04-03-2015, 08:59 PM   #1
asolde
asolde's Avatar
69-72 K-5 Blazer speaker
Lot of discussion about these speakers. This one is a nice one. I have not removed the grille to see the speaker it's self but I believe it to be in good condition. It has the welded nuts on the brackets. A nice grille and original screws in the grille. $155 shipped in the good ole USA.
1972 cheverolet K5 CST Blazer
350/auto/AC/PS/PB/Aux Batt
From Medford, Oregon
asolde is offline   Reply With Quote
Old 04-04-2015, 06:47 AM   #2
tristan
Re: 69-72 K-5 Blazer speaker
I'll take it, PM sent.
tristan is offline   Reply With Quote
Old 04-04-2015, 07:32 AM   #3
asolde
asolde's Avatar
Sold pending payment
Old 04-04-2015, 11:07 AM   #4
Gary 70 Jimmy
Gary 70 Jimmy's Avatar
Do you no how this one was mounted I have one with the same brackets with the nuts on them.
1972 GMC Jimmy 1/2 4X4 4wheel camper
1970 GMC Jimmy 1/2 4X4 350
1969 Chevy Blazer 1/2 4X4 307
1967 chevy LWB 3/4 396
Gary 70 Jimmy is offline   Reply With Quote
Old 04-04-2015, 12:37 PM   #5
asolde
asolde's Avatar
I believe that the 69/70 had them mounted under the dash just over your foot on the accelerator pedal there should be predrilled holes to mount it using the welded nuts. The 71/72 it was mounted under the dash below heater/AC controller using the same holes as the controller only without the nuts. Both ways have the same hole pattern. Just my observation and research. Others may say something different.
Old 04-04-2015, 03:16 PM   #6
Gary 70 Jimmy
Thanks i will check it out.
Old 04-04-2015, 04:39 PM   #7
briank
Asolde is correct, my 69 was mounted to the left of the controls. If you look near the steering column under the dash ,the holes are to the right ,near the indentation under the dash. Hard to explain but the left bracket bolts to the first hole to the right of the column under the dash, then the right bracket goes to the other hole.
briank is offline   Reply With Quote
Old 04-04-2015, 05:35 PM   #8
61Cadman
I have this same speaker in my 1971..
Is there a way to test this speaker to see if it works. My radio is turning on but I have no sound. We're these speakers supposed to be good speakers? What's all the discussion about these?
61Cadman is offline   Reply With Quote
Old 04-04-2015, 05:51 PM   #9
asolde
asolde's Avatar
Some of these speakers are 46 years old and exposed to the elements. There is a place to buy a reproduction speakers that fit perfect but I don't remember the web site.
There is discussion about where it is mounted either directly under the controller or to the left of it just above your foot on the accelerator pedal. Some Blazers had the speaker grille up on the dash like the trucks. Some say there was a speaker mounted behind the passenger seat in the sidewall panel. I believe that all of the scenarios are true. Just my opinion. Alex
Old 04-04-2015, 06:32 PM   #10
asolde
asolde's Avatar
The web site that sells a speaker is WWW.turnswitch.com
Old 04-04-2015, 06:33 PM   #11
Gary 70 Jimmy
I just got this one last weak end first one I ever seen in the console. I get my old speakers record so they still have the threads for the screws.
