Old 02-05-2004, 09:41 PM   #1
dwjack
oil pressure gauge
I just painted the instrument cluster for the "brighter dash lights" fix. Before assembling everything I thought I would test all the bulbs. The oil pressure gauge is pegging out with key on and when engine is running. I know before it sat to the far left with key on and the engine not running.
There are 3 connections on the back shaped like an upside down triangle. The top left has 12 volts and the bottom is ground. The top right has nothing unless you plug the gauge in and then it has about 8 or 9 volts that run through the switch.
Any thoughts on what my problem is before I put everything back together? It's alot easier to get to now.
1984 Silverado C10
GM Goodwrench 350
Edelbrock Intake/Carb
Hedman Hedders
700R4 Transmission
12 Bolt out of an 81
275/60/15 Centerlines
dwjack is offline   Reply With Quote
Old 02-06-2004, 12:37 AM   #2
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Sounds like the wire to the sending unit isnt plugged in.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 02-06-2004, 01:01 AM   #3
dwjack
I disconnected that wire and the tab that it attaches to pulled out of the sending unit. Guess I'll go get a new one tomorrow.
1984 Silverado C10
GM Goodwrench 350
Hedman Hedders
700R4 Transmission
