Closed Thread
Old 04-05-2015, 05:12 PM   #2001
SuperC10Tex
SuperC10Tex's Avatar
Re: What did you do to your truck today? Chapter II
Great day to put down my first coat of wax on Texas Touch after paint (been almost a year now).
1970 GMC Sierra Grande CST SWB Fleetside "Texas Touch"
"An intellectual is a man who takes more words than necessary to tell more than he knows"
SuperC10Tex is offline
Old 04-05-2015, 05:39 PM   #2002
Gravityamp
Gravityamp's Avatar
Originally Posted by bgwss View Post
Did you use a kit for the headlight relays? Where did you get it from?
I didn't use a kit . I went my local parts house and bought the relays , circuit breakers and wire . It didn't take very long to do . If you are thinking about doing it , go do it is all I can say !
There is no better upgrade that can be done especially for under 20 bucks !
Peace
69 GMC
400/400
2.5/4 drop from ECE
Gravityamp is offline
Old 04-05-2015, 05:44 PM   #2003
Gravityamp
Gravityamp's Avatar
Sweet GMC c10Tex
Looks absolutely gorgeous , great job
Peace
69 GMC
400/400
2.5/4 drop from ECE
Old 04-05-2015, 06:12 PM   #2004
Possmguts
Possmguts's Avatar
Peace
forgive the stupid question... but what do the relays do for the lights?
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 04-05-2015, 07:37 PM   #2005
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Beautiful truck super
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 04-05-2015, 07:58 PM   #2006
VWNate1
VWNate1's Avatar
Thumbs up Headlight Relays
NOT a stupid question ! .
Headlight relays make the headlights *much* brighter , even the 40 year old original seal beams .
They do this by increasing the amount of electrical power reaching the headlights ~ properly done you use slightly heavier gauge wiring between the battery and head lights , this also serves to take the load off that 40 year old low quality light switch .
For those who like up graded headlights , this is mandatory to get the full out put if the newer lights .
Don't forget to add a ground wire between the head lights and the battery's ground location be it the body , fender or frame .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 04-05-2015, 08:07 PM   #2007
Gravityamp
Gravityamp's Avatar
No such thing as a stupid question !
The relays bypass the power having to go thru all the wiring under dash and back to lights . I had a voltage reading on low beams at 10.8 and 8.9 on high beams at the lights now they have the full 12.8 at all times when headlights are on that is . I would say 25 % brighter lights on low 40% brighter on high
http://67-72chevytrucks.com/vboard/s...d.php?t=293913
Peace
69 GMC
400/400
2.5/4 drop from ECE
Old 04-05-2015, 10:05 PM   #2008
Possmguts
Possmguts's Avatar
Peace
Thank you sir... nice upgrade
Old 04-06-2015, 04:41 PM   #2009
Possmguts
Possmguts's Avatar
Assembled the rear end and got one step closer to having a roller.
Old 04-06-2015, 09:01 PM   #2010
colgad
colgad's Avatar
When out and got gas today, still working the bugs out. It's better everytime I take it out, fix a rattle here, tighten a bolt there, small airbag leak...
Clean it up and out the the Steak and Shake tomorrow night.
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline
Old 04-07-2015, 08:04 PM   #2011
Yooper truck
Yooper truck's Avatar
Success!!!! Not exactly a today only project. I replaced the brake system on my truck during the winter months. Today I took it off the jack stands and down the road for the first time since October.
I installed a power brake booster, replaced all brake lines, and replaced rear pads and hardware as well as having the drums turned. I was pretty happy seeing I have never worked on drum brakes or replaced lines before. I spent a lot of time watching Youtube tutorials. I learned a lot and have the satisfaction of accomplishment.
I am so pleased I just had to post.
Yooper truck is offline
Old 04-07-2015, 08:21 PM   #2012
truckkeepsmesane
truckkeepsmesane's Avatar
Took the passenger interior door panel off my 68 C20 so I could rig the driver's side door handle. Cleaned some grounds so I can get her cranked this weekend
truckkeepsmesane is offline
Old 04-07-2015, 09:56 PM   #2013
Lou Boffa
Lou Boffa's Avatar
Way to go!
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline
Old 04-07-2015, 10:21 PM   #2014
LPoole
LPoole's Avatar
was curious, is yours a drum/drum set up ? and what booster did you install ?
LPoole is offline
Old 04-07-2015, 11:29 PM   #2015
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Looks great SuperC10Tex. Me I won't use wax anymore. Not since it made my 72 yellow Chevelle look so badly. I've been using this since 1996, and couldn't be happier. They have great polishes as well. I used the mild to take off the wax.
http://www.detailsupplyoutlet.com/item.htm?item_num=115
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 04-07-2015, 11:50 PM   #2016
ole dollor
ole dollor's Avatar
do you have to order the stuff or can you get it from an auto supply store. looks like good stuff...Don
ole dollor is offline
Old 04-08-2015, 06:08 PM   #2017
Saclandman
Saclandman's Avatar
Bought a full set of new tires today. Nothing fancy, just some M+S's. Now to get them on the truck. Maybe tomorrow.
Rich J.
1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD
2002 Chevy Tahoe 4X4 5.3L SOLD
2015 Chevy Silverado Crew 4X4 5.3L
Saclandman is offline
Old 04-08-2015, 06:27 PM   #2018
Possmguts
Possmguts's Avatar
Did everything I could without U-bolts to get ready to install the rear end back where it belongs. The U-bolts should be here tomorrow and I can wrap that part up. I mounted the Wilwood brackets and just set the disks and calipers on just to see how its gonna fall together. Man what a nice disk brake setup. That drum style E-brake is really nice. None of those big ugly springs hanging off the calipers... just nice, clean and modern design.
Old 04-08-2015, 06:52 PM   #2019
boraxman
Keepin an eye out
boraxman's Avatar
I moved mine from the driveway to the street...Big day/
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline
Old 04-08-2015, 07:51 PM   #2020
tommy3horse
tommy3horse's Avatar
I spent the better part of Sunday pulling the pan on the TH350 to stop the leaking. I was pleased to have found very little crap in the pan. So, I changed the filter/gasket, cleaned and painted the pan and bolts, new modulator and topped it off with fluid. (Fluid just dripped out of the modulator too, yikes!).
Cranked it up and it was leaking worse than ever, looked like the pan again, but it was dry. Upon further inspection, I found the secondary accumulator cover leaking. I removed the clip and cover, and found the spring broken in 3 pcs and had damaged the cover.
I was lucky and had another tranny to get the parts I needed, woo-hoo!.
Got it all back together Monday afternoon and took it for a ride. NO LEAKS, its like a miracle. Shift like new, crisp into 2nd was something new fo this truck...replacing that broken spring helps here and smoothly but firmly into 3rd. The bad modulator was allowing the fluid to be sucked into the intake an burned, and of course, it was always "hunting" or "floating" into 3rd.
Spent time cleaning the spent trans fluid off the undercarriage and exhaust.
Time well spent!
Tom
1972 GMC C1500 350/350
1965 Mustang 2+2 289 4spd, show-car
1965 Mustang Coupe 289 4spd, stoplight racer
1/2 dozen Wheelhorse Tractors
tommy3horse is offline
Old 04-08-2015, 08:36 PM   #2021
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
I think I'm going nuts. I stared at this for five minutes and can't figure it out.
Are the brakes drum and the disk for the e-brake only?
Beautiful...And I know it's me...being a simple disk front/drum rear guy....Butt, What The %&*(^^?
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 04-08-2015, 08:39 PM   #2022
Possmguts
Possmguts's Avatar
Its like a newer disk setup where the rotor is also the drum for the E-brake.. the drum part is only for the E-brake, it works by cable... the disk part is what you stop with. Nice 4 piston calipers too
Old 04-09-2015, 06:00 PM   #2023
Saclandman
Saclandman's Avatar
Baby's got new shoes! More like work boots.
Rich J.
Old 04-11-2015, 04:18 PM   #2024
Yooper truck
No, it has disc up front and drums in the rear. I bought the booster from Classic Parts. It bolted in pretty easily. The biggest challenge was connecting the linkage to the brake pedal under the dash.
Old 04-11-2015, 09:07 PM   #2025
magwakeenercew2jh
http://magwa.smugmug.com/Tower-Car-Show-2015/i-dg9SzvS
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Closed Thread
