Closed Thread
Old 04-06-2015, 09:11 AM   #1
skeeterbug
skeeterbug's Avatar
Edited by staff
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
'71 LWB c10-"WORK" in progress
385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall
2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better)
2013 best 7.39
2014 best-7.38
New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage
skeeterbug is offline
Old 04-09-2015, 03:52 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: OEM p/s brakets for long water pump needed...
Originally Posted by skeeterbug View Post
Hopefully the moderators wont get upset that i listed this here, just seems to be more traffic here than on parts board. I'm in dire need of the original brackets for a sbc p/s pump with long water pump. Ive been using an aluminum aftermarket one that is aggravating as hell, but it finally crapped the bed. My truck is a race only application so im thinking the original steel ones will hold up much better.
Unfortunately you can't post a wanted to buy thread anywhere on the board unless you are a Premium member...(name in Blue) If you are a Premium member you still have to post stuff in the correct forum....
LockDoc
Leon
LockDoc is offline
Old 04-09-2015, 07:54 PM   #3
SS Tim
SS Tim's Avatar
The rules are in place for a reason.
Try Speedway Motors, www.speedwaymotors.com over in the racing and oval track parts section.
Like cheyenneshortstep said long pumps were 73 up on CK truck applications. So if you feel that will work try searching the 73-87 classifieds.
http://67-72chevytrucks.com/vboard/forumdisplay.php?f=5
If this is a "race only", I question carrying the weight of a power steering set up in the first place considering its factory listed as 33lbs over the stock manual box.
SS Tim is offline
Closed Thread
