Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 04-07-2015, 01:17 AM   #101
First c10
First c10's Avatar
Re: Project 68 k10 LWB..aka "The Hulk"
Worked on the front cross member tonight. I cut the pedistals down and fit them in the frame.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 04-07-2015, 01:20 AM   #102
First c10
First c10's Avatar
Welded a piece of flat stock and will drill the holes after I get them installed
GO GO!!!
Old 04-07-2015, 01:21 AM   #103
First c10
First c10's Avatar
After I test fit them I burned them in.
GO GO!!!
Old 04-07-2015, 01:24 AM   #104
First c10
First c10's Avatar
With the curve of the frame the square body crossmember I had to bend it down and weld a 1/8" piece to the bottom and then I will re drill the 7/16" hole.
GO GO!!!
Old 04-07-2015, 01:25 AM   #105
First c10
First c10's Avatar
Welded up now to bust out the grinder to grind down the excess. But I forgot to take a picture after the test fit. I will tomorrow. I took off a couple days so I can work on it a little.
I also got a 12 bolt to rebuild. I think I am going to put rear disc brakes on it. Starting with captainfabs brackets with e brake setup.
GO GO!!!
Old 04-07-2015, 01:31 AM   #106
First c10
First c10's Avatar
Just a little fun picture. The frame will be about 8" higher.
GO GO!!!
Old 04-07-2015, 09:57 AM   #107
7dee2
7dee2's Avatar
Looking good!
Brett
66 El Camino: BBC, 4sd. Waiting for its turn.
67 Camaro SS: 67 Camaro Build
72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build
72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 04-07-2015, 11:07 AM   #108
First c10
First c10's Avatar
Originally Posted by 7dee2 View Post
Looking good!
Thanks....
I am not sure if the am posting to much but thought what the heck it is a build thread!!!!
GO GO!!!
Old 04-07-2015, 03:35 PM   #109
7dee2
7dee2's Avatar
Post away, good stuff here!
Brett
Old 04-07-2015, 04:01 PM   #110
ryanroo
ryanroo's Avatar
did this guy just wonder if he posts to much? haha
post it all. we all love watching someone build a truck. pictures are the best. we are watching from the dark corners of the web.....
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 04-07-2015, 04:51 PM   #111
Nitis
Nitis's Avatar
Living vicariously through you bud
Nitis is offline   Reply With Quote
Old 04-07-2015, 08:35 PM   #112
First c10
First c10's Avatar
Thanks guys.
Ok here is my son media blasting the rear axle.
GO GO!!!
Old 04-07-2015, 08:47 PM   #113
First c10
First c10's Avatar
Put the front axle under the frame to see how the front end lines up. One thing I noticed was that the sway bar was towards the front of the frame more on the pass side. The mounts on the front crossmember I installed are square. Do you think it is a problem ? It's like 3/8"-1/2" off or 1/4" per side. The axle has to be right because of the leaf spring bolts.
GO GO!!!
Old 04-07-2015, 08:49 PM   #114
First c10
First c10's Avatar
Another of the front mounted.
GO GO!!!
Old 04-07-2015, 08:53 PM   #115
First c10
First c10's Avatar
I ordered a set of SS brake line from suspension connection when I ordered the lift. The block that mounts to the caliper is at an angle. Any ideas?
GO GO!!!
Old 04-07-2015, 08:55 PM   #116
First c10
First c10's Avatar
I even turned the block over.
GO GO!!!
Old 04-08-2015, 12:23 PM   #117
swamp rat
swamp rat's Avatar
The hose should be mounted like the last picture, the hose does angle away from the caliper normally. That said i'd almost think that the block was squished somehow before that hose was assembled, all my hoses have blocks that are straight and true, but if the sealing surfaces and the hole are machined true and perpendicular than it should be ok.
I got my braided stainless hosed from ORD.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-08-2015, 12:32 PM   #118
First c10
First c10's Avatar
Swamp
I just got off the phone with suspension connection they are going to send me out another pair as they and I think the were not machined correctly. I should have them by Monday the latest....not that they are holding me up.
GO GO!!!
Old 04-08-2015, 12:48 PM   #119
swamp rat
swamp rat's Avatar
One more thing, when you install you want your axle to be free hanging on the springs to be sure the line will still have a little slack in it, also turn the steering side to side when you check.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 04-08-2015, 01:04 PM   #120
First c10
First c10's Avatar
yes definitely will do that. The lines are for 6" lift and the lift I have is 4". so I should be ok, but I will check
GO GO!!!
Old 04-10-2015, 02:23 AM   #121
First c10
First c10's Avatar
Got something from the brown truck guys. Off-road Designs rear shackle flip kit, steering box brace, & new curved u bolts to replace the old square type.
Dwilbur said his brace didn't fit his style frame so guess what it didn't fit mine either. I had some 1/4" thick washers so I used 2. I mocked it up before I painted it but my phone went dead so no pictures till the final install
GO GO!!!
Old 04-10-2015, 02:26 AM   #122
First c10
First c10's Avatar
I did have to clearance the sway bar bracket I installed because it hit the steering box bracket.
GO GO!!!
Old 04-10-2015, 02:33 AM   #123
First c10
First c10's Avatar
Look what I came across....a 72 gmc a/c cab from a super camper. Has both doors, one is good one is trash. Has some drip well rust and rockers but floor and cab corners look good. Will have it blasted and then we will see if it is worth keeping.
GO GO!!!
Old 04-10-2015, 08:51 AM   #124
SDfarms
SDfarms's Avatar
Some people just get all the luck! I wish I could ad least find a cab! Projects looking great though heck of a job.
SDfarms is offline   Reply With Quote
Old 04-10-2015, 11:13 AM   #125
First c10
First c10's Avatar
Thanks Lance. The mechanical stuff is easy for me. Welding etc. but the body work? That is another story. This cab will need some work on the drop wells. The cowl vents and rocker will be pretty routine. Going to finish up the frame and get it into a roller then move the cab inside.
GO GO!!!
