12-06-2014, 10:20 AM | #26 | |
Re: Project: Nightmare
I'm not fixing it until it breaks. Plus, routing a new pipe around the mechanical clutch linkage is going to be a challenge. |
12-11-2014, 10:23 AM | #27 |
The next issue was the sway bar. The one I had was from Early Classic and it was made to bolt to the stock control arms. It wasn't going to work on the new arms. I called Choppin' Block and the guy happened to have a Porter Built sway bar that he said would work, so I bought it at a discount. Once I got it, I realized it just barely worked. I had to install it upside down for it to line up the best, and when I cut the wheel all the way, the tires rub on it.
If anyone knows of a better bar out there, please reply. The measurement between the two bolt holes for the end links is 44 inches. |
12-11-2014, 11:31 AM | #28 |
Finally got it back on the road. I'm pretty happy with the ride, definitely a big improvement over coil springs. The time and the work to get to this point was insane though, I racked my brain trying to engineer the setup to get everything to work together, and I was literally watching the seasons change as I waited for parts, so be prepared for this kind of BS if you want to build your own air ride system. To put it in perspective, I think my engine build was easier.
I still have some air leaks around the tank and valves, I'll be posting about that soon. |
12-29-2014, 10:43 AM | #29 |
I came up with an idea to correct the front shocks. These shocks were on it before I did the air ride. They just barely worked, too short, binding against the frame, causing them to leak. I needed to make room for longer shocks.
12-29-2014, 10:50 AM | #30 |
I couldn't get to the old shock bolts on the inside of the frame, so I just cut them off for now. I made some measurements and realized I could just cut out some of the inner fender for longer shocks. Turns out, stock rear shocks work. I found a piece of square tubing at Lowe's and drilled out the frame.
12-29-2014, 10:56 AM | #31 |
It's pretty simply and crude, but it works, that's what matters. I left some length on the square stock for when it comes time to lower it more.
For reference, Here's a shot of it aired up all the way... |
12-29-2014, 11:09 AM | #32 |
Just wondering, am I the only one on this entire forum with Choppin' Block Control Arms?
I've had zero feedback about them, and I can't find anything on google... |
02-09-2015, 12:43 PM | #33 |
It's been awhile since I posted anything, the weather's been too lousy to do any driving, so the truck's been sitting and waiting. The new garage is coming in handy for a lot of things.
I fixed some air leaks around my valves and changed the configuration at the same time to simplify and save space in the bed. This is was my initial setup: |
02-09-2015, 12:48 PM | #34 |
And here's the new setup. I built a box with pressure-treated to keep the weather off it.
02-09-2015, 12:55 PM | #35 |
I had to keep it outside for a bit while they wired up the garage. Can't wait for a nice day to take it out on the roads, it looks like it wants to be driven.
02-09-2015, 01:14 PM | #36 |
I like it laid out on the whitewalls
02-09-2015, 01:59 PM | #37 |
02-10-2015, 04:08 AM | #38 |
Then you can push snow with your front bumper!
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
02-10-2015, 10:26 AM | #39 |
02-15-2015, 11:00 PM | #40 |
Lol I know how that is. My field is a muddy mess. Can't even move my truck. Wait till summer to drive it and I'll be doing the same thing. I got a new pair of drag radials and a pair of slicks I'd like to burn lol
02-16-2015, 07:44 PM | #41 |
04-10-2015, 12:09 PM | #42 |
uhm??!! am i the oly one that saw the Deer? i feel like im stocking you man, but the akwardness of you build has caught my eye!
04-10-2015, 12:24 PM | #43 |
Haha yea you're the first to comment on the deer. Thanks for checking out my build, that's what it's on here for!
Where's the link for yours? |
04-10-2015, 01:38 PM | #44 |
haven't gotten to that point yet unfortunately. Hopefully this year will bring a ton of parts to put my dad's old truck back together the right way and not with job weld and coat hangers. Lol.
