Old 04-08-2015, 11:21 PM   #1
tjsblazer
tjsblazer's Avatar
X - Member Hardware size?
Hey guys, are the bolts for the Engine x-member / stands and transmission x-member 3/8" or 7/16" ? I threw mine out months ago now I can't remember when I'm putting it back together. Thanks.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 04-09-2015, 02:09 AM   #2
El Dorado Jim
Re: X - Member Hardware size?
I use 3/8" grade 5 bolts
El Dorado Jim is offline   Reply With Quote
Old 04-09-2015, 07:44 AM   #3
cdowns
cdowns's Avatar
try measuring the holes
Old 04-09-2015, 08:06 AM   #4
tjsblazer
tjsblazer's Avatar
Hey, hey. Yeah thanks. I did that. They are under 7/16 a bit. Around .410 but I thought maybe that was from the powder coating.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 04-09-2015, 10:56 AM   #5
WIDESIDE72
WIDESIDE72's Avatar
I helped a buddy install a ramjet 350 in his 68. He was trying to install the engine to the mounts with the 7/16 bolts that the previous owner used on the old 350. He was wresting with it and had removed the bolts holding the frame stands in.
I told him to use 3/8" bolts, since all of the truck I had worked on parted/ otherwise all used that size. He argued that it had 7/16" when he took it apart. I told him to keep wrestling if he wanted, but not me.
He finally gave in and went and bought grade 8 3/8" and had no trouble.
The issue is, a little room is needed for adjustability. If you try and use 7/16" you lose that adjustability. This is the same reason why if you have multiple fasteners in something, you leave them all loose until you get all of the fasteners in place.
WIDESIDE72 is offline   Reply With Quote
Old 04-10-2015, 08:53 PM   #6
tjsblazer
tjsblazer's Avatar
Thanks everyone. 3/8 worked great. I used grade 8 not sure if it was really required.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
