Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 04-10-2015, 10:20 PM   #51
tjsblazer
tjsblazer's Avatar
Re: tjs 72 Blazer Build
So I decided to use 73+ front spring u-bolt plates so I could add a front sway bar down the road if I wanted. However the axle and housing on the 72 is 2.75 and 3.5" so I had to elongate slightly with an end mill and take 0.125" out of each hole.
[IMG][/IMG]
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 04-10-2015, 10:24 PM   #52
tjsblazer
tjsblazer's Avatar
I had to cut my original Fuel tank hanger bracket to get it out so I made a new one. I got some 3/8" cold rolled rod, shaped to match a factory one and cut some threads. I just need to add some black paint or powder.
[IMG][/IMG]
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 04-10-2015, 10:26 PM   #53
tjsblazer
tjsblazer's Avatar
Some more garage paint booth action. NV4500 transmission case this time.
[IMG][/IMG]
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 04-10-2015, 10:28 PM   #54
tjsblazer
tjsblazer's Avatar
Got a bag of items zinc plated. All the brake/fuel line clips. They had a minimum charge so I got the fuel fill pipe and some small brake parts that were all rusty redone.
[IMG][/IMG]
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 04-10-2015, 10:32 PM   #55
tjsblazer
tjsblazer's Avatar
These things are like a jigsaw puzzle. This took a service manual, some online pictures and a lot of my time. My first set of Drums ever. Calipers and rotors are soooo much easier. Ugghh, Right after I was done I noticed that the backing plate bolts were reversed to put the nut outside so I swapped them around.
[IMG][/IMG]
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 04-10-2015, 10:34 PM   #56
tjsblazer
tjsblazer's Avatar
It feels soooo good to finally be putting something TOGETHER. Too many months of taking apart and cleaning / painting. Have a couple of days to put back some chassis together. Hopefully some more updates over the weekend. Cheers.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 04-11-2015, 12:54 AM   #57
jimbosprint
jimbosprint's Avatar
Nice update
jimbosprint is offline   Reply With Quote
Old 04-11-2015, 12:04 PM   #58
tjsblazer
tjsblazer's Avatar
Got the springs hung. Rears were a b*tch with the bit of pre-load in them.
[IMG][/IMG]
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 04-11-2015, 12:33 PM   #59
IronCanine
I'm trying....
IronCanine's Avatar
[IMG][/IMG]
Isn't that just the best. I wish I had sent more stuff to be coated myself.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 04-11-2015, 07:36 PM   #60
tjsblazer
tjsblazer's Avatar
Yes, I'm glad I got them done. I was grabbing anything I could think of Chassis wise. I had some Grade 8 U bolts I got made at the local spring shop and got them plated in the same lot.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 04-11-2015, 07:44 PM   #61
tjsblazer
tjsblazer's Avatar
Front axle back together. Thanks to those here who have recently gone before me, I was well versed on how to get the Ball joint pre-loads set correctly. I put new front axles in but they don't make the 71/72. Have to get 73+. Just means the larger U-joint. Just barely fits through the knuckle! Also the seal at the back of the Spindle is a little different, I had to machined my 72 spindle 0.125 deeper where the spindle bearing and seal go. In the end it all went together no problem after lots of homework ahead of time.
[IMG][/IMG]
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 04-11-2015, 08:02 PM   #62
tjsblazer
tjsblazer's Avatar
Getting the steering Gear box rehung.
[IMG][/IMG]
[IMG][/IMG]
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 04-11-2015, 08:22 PM   #63
tjsblazer
tjsblazer's Avatar
Axles hung.
[IMG][/IMG]
[IMG][/IMG]
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 04-11-2015, 08:25 PM   #64
jaros44sr
jaros44sr's Avatar
Axles hung.
[IMG][/IMG]
[IMG][/IMG]
Hey Jeff, nice work. Another one to follow. What coating did you use on your brake drums
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 04-11-2015, 10:16 PM   #65
tjsblazer
tjsblazer's Avatar
Thank you. I used high temp manifold/header paint.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 04-11-2015, 10:21 PM   #66
jaros44sr
jaros44sr's Avatar
Perfect idea,ty
SAFETY FIRST
AS usual, off topic
Jim
Old 04-11-2015, 10:39 PM   #67
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Looks great! How are the hub dials holding up as regards the blue color and where did you get the plating done?
Old 04-11-2015, 10:50 PM   #68
tjsblazer
tjsblazer's Avatar
Thanks Pete. So far dials look the same as when they were first cleaned up. Mind you, they have just been sitting on my work bench.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 04-11-2015, 10:57 PM   #69
tjsblazer
tjsblazer's Avatar
It was time to get the weight off of the 40 year old wooden saw horses that were holding it. I think the legs were about to snap off. They were fine when it was just the weight of the frame. So I have a "roller". I'll work on the hard fuel and brake lines over the next week.
[IMG][/IMG]
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 04-11-2015, 10:59 PM   #70
tjsblazer
tjsblazer's Avatar
I had 15 mins of play time left today before dinner so I managed to get the Clutch on the Engine.
[IMG][/IMG]
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 04-11-2015, 11:03 PM   #71
GMC-YA68
GMC-YA68's Avatar
looking BADAZZ!
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 04-11-2015, 11:04 PM   #72
tjsblazer
tjsblazer's Avatar
Sorry, I missed your second question. I just used a local plating shop in the closest city to me here in Ontario, Canada. They do all zinc, cadmium, nickel, and anodizing.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 04-12-2015, 06:58 AM   #73
grillzy
Looking great!
grillzy is offline   Reply With Quote
Old 04-12-2015, 07:38 AM   #74
jaros44sr
jaros44sr's Avatar
Jeff, if you are going to use the OEM spark plug wire looms, now is the time to mount the rear looms, they are a son of a gun to install once the engine is in. I used studs, easier for install
Great assembly work
SAFETY FIRST
AS usual, off topic
Jim
Old 04-12-2015, 02:03 PM   #75
tjsblazer
tjsblazer's Avatar
Great assembly work
You know I hadnt thought that far ahead. You bring up a great point. I'm going to start to think through some of the routing. I am going to run a set of Stan's TriY headers so I'm not yet sure if I will run plug wires over or under.
Thanks for the heads up.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
