Old 04-12-2015, 07:40 PM   #1
canadian_diesel1964
283 2 bbl line from carb to back of block?
I just removed a large vacuum type line from the back of the 2 bbl carb on my 63 283. The line went to a rubber grommet at the back of the block just aft of the manifold. Is this a vacuum line? Or a vent line? It had a huge crack and hole in it the size of a dime so I think it wasn't doing anything...thanx guys I don't know the 283 that well at all.
canadian_diesel1964 is offline   Reply With Quote
Old 04-12-2015, 08:55 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: 283 2 bbl line from carb to back of block?
When the engine first designed, there would have had a "Road draft tube" in the hole behind the intake manifold. Here's an example:
http://www.lategreatchevy.com/chevy-...1958-1962.html
As the vehicle traveled down the road, a "draft" (low pressure area) was created at the bottom of the tube which drew fumes out of the crankcase.
With the development of positive crankcase ventilation (PCV), the road draft tube was eliminated. Initially an adapter was bolted in the draft tube hole in the block, and a hose ran to a PCV valve and on to the base of the carburetor.
As these adapters are now very hard to find, many owners stick a valve cover grommet in the block hole, insert a compatible smog valve, and run a hose to the carb base. Any of these arrangements will work, provided there is either a breather cap on the oil fill pipe, or one (or both) of the valve covers.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 04-13-2015, 12:37 AM   #3
Captainfab
60-66 Nut
Here is another current thread regarding the crankcase venting of the '67 and earlier small blocks.
http://www.67-72chevytrucks.com/vboa...d.php?t=666223
Old 04-13-2015, 06:48 AM   #4
canadian_diesel1964
Thank you gentlemen!
