Old 04-13-2015, 01:28 PM   #1
81GMCSierra1500
81GMCSierra1500's Avatar
Lighting Issue
hey again all...
I went to turn my headlights on the other day, and head a faint "pop" come from under the dashboard, upon later inspection, only the headlights would turn on, there are literally NO other lights on, no exterior marker lights, not even the dash lights. but all turn signals and hazard circuits still work. I replaced the light switch (which was brand new), and nothing changed. I've checked all bulbs, they're all good, so it has to be a running lights fuse... I can't read anything on my old, faded fuse block, and the diagram in my Haynes repair manual is IMPOSSIBLE to read... It's the fuse block with the hazard flasher in the top left corner and the turn flasher in the bottom left corner with 2 white plugs on the left side. I'm thinking one of those fuses blew up, but I can't get those plugs out of the fuse block for the life of me. What is wrong?
1981 Sierra Classic 1500, 305 4BBL, Ltd. Slip Rear End
81GMCSierra1500 is offline   Reply With Quote
Old 04-13-2015, 06:36 PM   #2
86c20
86c20's Avatar
Re: Lighting Issue
best way is to check with a test light and just go one at a time. never know what has be hacked in over the years unless you got her new
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
