04-13-2015, 03:20 PM | #1 |
64 Lower Control Arm, Replacement Needed
Hi Guys,
I need a little advice please, I've just removed the control arm bushes from my 64 C10. One of the passenger side lower bushes was worn and split and the hole ine the control arm is worn oversize. I will need to find a replacement but living in England my choices may be limited. My question, am I limited to 1963/64 control arms or will arms from other years fit? I reckon the more options I have, the greater my chance of finding one Many thanks Last edited by ibrown50; 04-13-2015 at 03:37 PM. |
04-13-2015, 03:22 PM | #2 |
I'm just glad to be here!
Re: 64 Lower Control Arm, Replacement Needed
Lower arms from a '63 thru '72 should work for you.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
04-13-2015, 03:51 PM | #3 |
Karl
Many thanks Ian |
04-13-2015, 05:43 PM | #4 |
i have one if you can look into shipping as ive never shipped overseas
zip code is 87121 New Mexico
1967custom |
04-14-2015, 06:41 AM | #5 |
I have everything out the front of my 66 if you need an a arm. One thing to think about is doing the disc brake conversion. That ups your choices to the 73 to 87 a arms. If you look at the disc conversion thread you can get lots of mere detailed information.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
04-14-2015, 11:25 AM | #6 | |
