Old 04-13-2015, 10:24 AM   #1
Pzary3233
68 C10 6" rear drop issues
I finished up the rear drop on my 68 LWB truck this weekend. I am not sure if I got the incorrect springs, or what. The rear end is sitting on the frame. From what I have gathered with a 6" drop the c-notch is not mandatory. However In my case it must be.
Older shot with the 7" 6 lug truck ralleys.
My suspension is as follows
CPP 4" springs - RCS603-4
Way2lo2's 2" lowering Blocks
CPP Deluxe Panhard Bar
CPP Shock Relocation Kit
Monroe Shocks.
15x10 with a 275/60/15
The truck is sitting perfect now, but I am afraid that even with a C-Notch the spring isn't going to be tall enough...
The odd thing is that the front end has the following parts and seems like it is actually a little higher....
CPP 2.5" Drop Spindles
CPP 3" Springs
'55 3200 283 4 speed
'68 Pontiac Firebird Poncho powered with a 6 speed
Pzary3233 is offline   Reply With Quote
Old 04-13-2015, 10:29 AM   #2
5150
C10 Club Tennessee
5150's Avatar
Re: 68 C10 6" rear drop issues
4 inches and the C-Notch is probably not mandatory. Anything over that it's "strongly" recommended.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 04-13-2015, 11:15 AM   #3
Pzary3233
Well I guess that's the plan then, C notch this coming weekend! I just don't want to do the notch and then have the rear end sit any further down...
Old 04-13-2015, 11:50 AM   #4
5150
C10 Club Tennessee
5150's Avatar
It won't effect the drop on the rear. I just did the passenger side of my daughter's frame last week.
Bryan
www.gmtruckshow.com
Old 04-13-2015, 12:30 PM   #5
Pzary3233
It will affect the rear drop if the rear end is currently sitting on the frame at rest... Without the springs holding up the full weight of the truck the rear end will move up until they do...
Old 04-13-2015, 08:18 PM   #6
RaceAGMC
RaceAGMC's Avatar
If you're running a 6" spring and 2" block that's why you're rear end is bottomed out on the frame. Remove the block and it will raise it up so you've got travel...or notch it so you have travel.
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
Old 04-13-2015, 10:29 PM   #7
Pzary3233
It has a 4" spring according to what I ordered and what was printed on the spring and a 2" block.
Old 04-14-2015, 01:03 PM   #8
michael bustamante
michael bustamante's Avatar
the ccp 4" springs are actually kind of soft. theyre chevelle springs actually. i bet if you lose the blocks the springs will have reach to carry the weight of the truck before resting on the axle
1967custom
michael bustamante is offline   Reply With Quote
Old 04-14-2015, 01:20 PM   #9
Pzary3233
I was wondering about that... Very good point, I googl'ed the part number and noticed that they were used on A Bodies as well...
I am wondering if the HD springs would be any better?
Old 04-14-2015, 01:24 PM   #10
michael bustamante
oh yeah im sure it would but it might make the ride stiffer as well. i have the cpp 4" rears myself and I do NOT like em. i just bought a set of earlyclassics 4" drop to replace them.
1967custom
