Re: What parts of the original harness are needed?
basically you just need the wire to power up your LS, harness, the wire that originally went to your distributor. You will most likley need to keep the starter wire too.You will probably want to keep the wires for the temp and oil pressure gauges also.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html Last edited by ls1nova71; 04-15-2015 at 08:27 AM. |
| Bookmarks |
