Old 04-14-2015, 11:06 PM   #1
OgCoda
Registered six offender
Just picked up a 1963 Chevy it has a straight six in it and everything seems to be stock. Just wondering what you guys are doing to spice these things up a bit. Not looking to have a race motor but if like to get a bit more power out of this thing. Also not sure witch six is in it.
OgCoda is offline   Reply With Quote
Old 04-14-2015, 11:32 PM   #2
TJ's Chevy
TJ's Chevy's Avatar
Re: Registered six offender
4 inch sidecovers and you'll have a 230, 6 inch side covers and you have a 292. For what your desiring....4 barrel, headers, hei and 5 speed would be optimum.
Old 04-15-2015, 01:32 AM   #3
slepysal
slepysal's Avatar
You should also add an electronic distributor or a pertronix module
Do a search for tricked out six
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 04-15-2015, 07:26 AM   #4
Keith Seymore
Keith Seymore's Avatar
LOL. Nice -
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 04-15-2015, 10:11 AM   #5
OgCoda
Cool thanks guys. Also I don't know if you guys have seen this before( I don't know of this is stock) but the trucks rear suspension has a half a leaf spring and a coil sping?
Old 04-15-2015, 10:34 AM   #6
TJ's Chevy
TJ's Chevy's Avatar
You have the "Heavy duty" overload springs.
Old 04-15-2015, 10:37 AM   #7
1963c-10
1963c-10's Avatar
Look something like this? As TJ said they are auxiliary springs
1964 Short bed trailer
Old 04-15-2015, 10:45 AM   #8
Old Truck Man
Old Truck Man's Avatar
Its likely what your referring to a half leaf spring is actually overload springa . they attach near the rear of the frame and the end will bump stop against a metal attached between the rear housing and trailing arms. Heres pictures of the souped up 250 six in my 66 GMC. Its a 68 250 bored .040 offenhauser 4 bbl intake & valve cover. Hedders and a RV cam. Hei ignition. Backed by a powerglide trans.
Old Truck Man is offline   Reply With Quote
Old 04-15-2015, 10:51 AM   #9
TJ's Chevy
TJ's Chevy's Avatar
FWIW, Here's a picture of my 292 in my 66 chevy. Bone stock with a 600 edelbrock, clifford intake, clifford headers, and HEI. Pulls perrty darn good for being as worn out as it is. And here are a couple performance videos.
https://www.youtube.com/watch?v=7b3OpLWMb4E
https://www.youtube.com/watch?v=YoiM0nIA_7c
https://www.youtube.com/watch?v=ifh4eU5bUAo
Old 04-15-2015, 12:02 PM   #10
OgCoda
Thank you guys very much for your responses also I was wondering if I take out that extra spring will it drop my truck or would the drop be too much without a notch? I also just emailed pertronix to see what set up they would recommend for my truck.
Old 04-15-2015, 12:06 PM   #11
TJ's Chevy
TJ's Chevy's Avatar
It shouldn't drop the truck. As far as pertronix goes all you have to do is call your local Napa or auto zone and tell them you want a Pertronix for a 250 and it'll fit your distributor just fine. And here's an HEI I would recommend. I've been using it and it has work great. http://www.ebay.com/itm/CHEVY-INLINE...a9fe0a&vxp=mtr
Old 04-15-2015, 12:32 PM   #12
OgCoda
So I buy the new hei distributor, And then put the pertronix module on the new distributor?
Old 04-15-2015, 12:34 PM   #13
TJ's Chevy
TJ's Chevy's Avatar
No no no. lol This HEI is a distributor and has everything you need. The pertronix is a replacement for your points distributor. An HEI is a whole different setup. That hei will bolt in and all you'll need is new plug wires and to hook your wires on.
Old 04-15-2015, 12:47 PM   #14
OgCoda
I understand what the hei is I've used them in other sbc builds I've done in the past. I've just never used the pertronix module. So I can use my stock distributor and replace the points with the pertronix module? Also if running the pertronix module I'm assuming I still need to run the coil? Where as the hei has the coil in the distributor?
Old 04-15-2015, 12:51 PM   #15
TJ's Chevy
TJ's Chevy's Avatar
Yes you will have to buy the flame thrower coil as well that pertronix sells. The HEI I listed a link for you on ebay has the coil in it. It is like a SBC hei but a 6 cylinder version.
Old 04-15-2015, 02:17 PM   #16
1963c-10
1963c-10's Avatar
If you look in the pic I posted on post 7 you can see the space between the spring and the mating pad. The spring should not be touching the pad on the rear end unless the truck is very loaded. There should be some space between the auxiliary spring and the pad. They only function as an overload spring when the truck has reached an "overload" weight. They just unbolt from the frame. The pads they mate too would require the trailing arms to be dropped to remove. If you don't plan to use them I'd stick them on the classifieds as they are not rare, but desired by a lot of people. I have them on both of my 63's.
Also....3 springs would be the 60-66 set up, they went to a single spring I believe in 67 and they will interchange.
Old 04-15-2015, 04:20 PM   #17
forestb
forestb's Avatar
What is the chain going from the block to the frame for?
forestb is offline   Reply With Quote
Old 04-15-2015, 04:42 PM   #18
aggie91
I'm just glad to be here!
aggie91's Avatar
Torque limiter so the engine torque does not rip the driver side motor mount apart...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 04-15-2015, 05:41 PM   #19
OgCoda
So this is my motor. Not sure what it is. The valve cover is shorter then 6" but the fuel pump is located where the 292 pump is and it has the 292 water jacket. ��
Also where the red circle is, there is a pretty bad exhaust leak. Does anyone know where I can find that gasket?
Old 04-15-2015, 07:30 PM   #20
slepysal
slepysal's Avatar
The gasket should come with the exhaust manifold gasket set.
Old 04-15-2015, 07:31 PM   #21
slepysal
slepysal's Avatar
here is a pic of my 250
Old 04-15-2015, 08:54 PM   #22
OgCoda
Anyone know what this motor is?
Old 04-15-2015, 08:56 PM   #23
TJ's Chevy
TJ's Chevy's Avatar
You have a 292. Great engine for spicing up. I've done several tests on my 292's so hit me up anytime you need info.
Old 04-15-2015, 09:34 PM   #24
jimmyjammoto
That large bypass hose is a 292 thing too
jimmyjammoto is offline   Reply With Quote
Old 04-15-2015, 10:40 PM   #25
Softpatch
Softpatch's Avatar
six bangers are cool drove em for yrs for a moment wish I still had one but just for a moment I have a sweet set up now and injoying that (350/350)..
picked up a third pedal set up for my truck because you never know what tomorow will bring Might go back to 4spd
....Sp
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
