Old 04-14-2015, 07:56 AM   #1
rideblue00
rideblue00's Avatar
Hubcap ???
Anyone know if 66 van hubcaps fit our stock rims? I picked up a set off ebay and they are really shallow. I also picked up a set of caps that are similar to c20 caps. But they have a really wide ring! What rims are they for? Thanks
Tom
rideblue00 is offline   Reply With Quote
Old 04-14-2015, 09:46 AM   #2
pimpston65
pimpston65's Avatar
Re: Hubcap ???
Tom
no and 3/4ton!!! the van caps are too shallow to fit over the nubs and hold tightly, the wide inner ring is for wheels with the clips... post a few pics, but im sure thats what u have, i been down that road many times!!! that backside of the hubcaps tells the tale...
pimpston65 is offline   Reply With Quote
Old 04-14-2015, 11:15 AM   #3
rideblue00
rideblue00's Avatar
Re: Hubcap ???
My c20 caps are different than these. These have a really wide ring. Are they for the 19.5 rims?
Old 04-14-2015, 11:17 AM   #4
rideblue00
rideblue00's Avatar
Re: Hubcap ???
Yeah ill post some pics later. But i know my c20 caps are correct. I dont think the wider ring will fit my 16" rims.
Old 04-14-2015, 11:35 AM   #5
Layne
Re: Hubcap ???
Oh man, I thought I was gonna find another avenue to locate c20 hubcaps.
Oh well. I'd like to see a pic also. just for curiosity sake.
Layne is offline   Reply With Quote
Old 04-14-2015, 11:44 AM   #6
pimpston65
pimpston65's Avatar
Re: Hubcap ???
the larger ring fits many clips styles i think, measure the inner diameter to tell...
Old 04-14-2015, 12:08 PM   #7
oem4me
Re: Hubcap ???
In a nutshell, there are just a few thing to keep in mind for fitment:
1) Ring or no ring. All NO RING caps fit 1/2 TON trucks with nubs and NO CLIPS , except van caps, which look identical front and back, but are too shallow.
2) Wide ring or narrow ring. These are for wheels with clips.
A wider ring makes for a smaller opening. Smaller opening means 1/2 TON.
Narrower ring makes a larger opening. These are for 3/4 TON. No such thing as a ringless cap for 3/4 ton in our generation.
It's pretty simple once you can recognize the differences.
Old 04-14-2015, 12:11 PM   #8
pimpston65
pimpston65's Avatar
Re: Hubcap ???
the GODS have spoken!!! nuff said...
Old 04-14-2015, 02:26 PM   #9
60-66
60-66's Avatar
Re: Hubcap ???
Hubcaps from left to right.
1/2 ton Nub style 6 bolt rims
1/2 ton Clip style 6 bolt only rims
3/4 and one ton 8 lug clip style rims
Hope this helps
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 04-14-2015, 03:36 PM   #10
Layne
Re: Hubcap ???
Thanks for the pics!
A picture is truly worth a thousand words!
Old 04-14-2015, 05:00 PM   #11
Layne
Re: Hubcap ???
Wait. Left to right? That would make the larger cap to the left for a 1/2 ton, and the smaller cap to the right for 3/4 ton?
Old 04-14-2015, 05:29 PM   #12
60-66
60-66's Avatar
Re: Hubcap ???
The one on the left fits over nub wheels. Physically these caps are all the same exact outer diameter . IF it looks bigger, its the picture . Only difference is whats done to the back. I have swapped the clip rings from one cap to another , a few guys have taken rings and put in nub caps.
Old 04-14-2015, 09:27 PM   #13
OldGMJon
OldGMJon's Avatar
Question Re: Hubcap ???
[QUOTE=oem4me;7132861]
In a nutshell, there are just a couple things to keep in mind for fitment:
1) Wide ring or narrow ring. These are for wheels with clips.
A) wider ring makes for a smaller opening. Smaller opening means 1/2 TON.
B) Narrower ring makes a larger opening. These are for 3/4 TON.
2) All NO RING caps fit 1/2 TON trucks with nub rims without CLIPS,
No such thing as a ring less cap for 3/4 ton in our generation. QUOTE]
So my 15" clipless/nubbie rims will accept any ringless hubcap except the van caps?
How much shallower are they? Dimensions so not to get wrong cap...
Projects:
65' Chevy C10 swb (rebuilt chassis)
65' Chevy Panel swb
64' Chevy C30 flatbed "above" 80' C30 "beneath")
Parts:
66' GMC 2503 & 65' GMC I1500
OldGMJon is offline   Reply With Quote
Old 04-14-2015, 09:52 PM   #14
rideblue00
rideblue00's Avatar
Re: Hubcap ???
Ok i think i have it straight now.
Upper left: 1/2t cap
Lower left: 3/4t cap both undisputable as i have
both style rims
Middle lower/lower right: 1/2t clip type (in 66 really?)
Middle upper/upper right: Van? (Shallow and 9.75 dia)
Old 04-14-2015, 10:11 PM   #15
rideblue00
rideblue00's Avatar
Re: Hubcap ???
I just want to be sure that the shallow ones are van ones. (What else could they be lol) i need to re-sell these as i cant use them.
Old 04-15-2015, 10:20 PM   #16
sodly
sodly's Avatar
Re: Hubcap ???
I was wondering the same thing. That GMC cap looks way bigger in the photo. Whew! Scared me for a second there. That's quite the optical illusion!
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
sodly is offline   Reply With Quote
Old 04-16-2015, 06:22 PM   #17
factorystock
factorystock's Avatar
Re: Hubcap ???
Post # 4 http://67-72chevytrucks.com/vboard/s...d.php?t=665937
factorystock is offline   Reply With Quote
Old 04-16-2015, 06:53 PM   #18
rideblue00
rideblue00's Avatar
Re: Hubcap ???
Good info there! This post keeps getting longer lol
