Old 04-17-2015, 09:25 AM   #1
A1971Blazer
A1971Blazer's Avatar
Re: Oil pressure port....?
Originally Posted by uxdesigner View Post
I'm also considering these exact gauges and interested on how you setup the oil and speedometer. Wondering if the speedometer is a simple plug and play, single wire VSS? Please post pics as you go, good luck!
Will do......but I'm a long way from there......
I glanced through the instructions briefly when I got the gauge assembly. It will work fine with the VSS but it requires their signal converter.
I assume that would be to used calibrate the speedometer with different tire sizes, gears etc.....? Luckily I got that with the kit too.....
Signal Converter
A1971Blazer is offline   Reply With Quote
