![]() Join Date: Aug 2013
calling "6" bangers boys!!!
i fully restored these two carbs only to find one has a bigger bottom butterfly, its going on my 292. how much, if any noticeable performance will be lost if i use the the more yellow cadmium one??? just cuz it looks NOS...
![]() Join Date: Jun 2011
Re: calling "6" bangers boys!!!
if you wanted it NOS looking why not install the nicer looking one and have the one you want replated in zinc or yellow cadmium in the meantime.
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
do you know of any platers, cuz the ones around me only do big jobs. the ones that will do it want more then NOS...
![]() Join Date: Mar 2013
Those are two different carbs....one for a 292 and the other probably for a 230 or 250. Yes you will loose power with the smaller butterfly....less air flow. Both look stock to me so I'd use the bigger one.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
thks TJ, the nicer one is from a 230, dang it!!! the 292 one just looks lame next to my fresh paint, i did see one claiming to be 292 NOS and it was yellow cad. i think mine is just faded...
![]() Join Date: Nov 2013
Maybe a stupid question, but shouldn't you be able to take the bottom section with the bigger butterfly and mate it to the newer cad plated upper carb section?
With that said - you may not want to because they look different in coloration... |
its a smart question, but thats what my plans were. thats how i found out they are different, plus the nicer one has passageways miled into the bottom between the cast iron mounting piece, so i dont wanna cuz issues. ima take them both to my carb guy and see what he thinks!!!
the airhorn or top piece has the same part number so that wouldnt be a problem with swap, it dosent look as nice thou. im going for looks and function!!!
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
This is the place I used in the past and have suggested to people. They'll restore your carb with the proper plating as well.
http://www.carbrebuilders.com/aboutus.htm
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
Why not get yerself a good rebuilt one from Autozone? Color don't matter cause they were grey anyway. Least the one that was on my 292 is.
I think you meant "doesn't" so my reply. lol THEN PAINT IT YELLOW!!!!
i figured it out, i took the top(airhorn) which is same part# and added it to the 292 bottom and base!!! then i put the levers from the nicer one. looks and workd perfect!!!
got the nos look now!!!
#15 |
thks for the idea, it worked!!!
#16 |
Looks very nice! I'm gonna have to subscribe to yer build so I can see more pics! lol
#17 |
#18 |
