04-20-2015, 01:04 PM | #101 |
Re: URGENT! Major problem! Need assistance!
1. Like a couple of idiots we re-installed a flex plate with a few teeth missing during the rebuild, because we were in the middle of nowhere and chose not to get a new one...................I'll have it replaced sometime in the future. The rebuild was 22 years ago and guess what? No problems, though on occasion It sticks a bit.
2. I had some issues two years ago, and at some point it sounded similar to yours. I replaced two starters, and added shims for it, so the starter was out at least three times before it was right. I also replaced the battery once. Lessons learned: A. Never go cheap on a battery. It should be high quality. B. Be sure the starter is high quality. C. It hasn't been a problem, but darn I wish I had replaced that flex plate. Incidentally, you'll make life easier adding connectors for the two wires to the starter. I use these:
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
