Old 04-20-2015, 06:29 PM   #1
Rwalkup
Rwalkup's Avatar
Which leaves do I take out?
trying to lower my 1948 3100 Chevy pickup. On the rear, which leaves do y'all recommend to remove? i'm looking to gain a couple inches lower.
Rwalkup is offline   Reply With Quote
Old 04-21-2015, 12:25 PM   #2
_Ogre
_Ogre's Avatar
Re: Which leaves do I take out?
not sure how much you can lower a truck just by removing leaves.
i did remove the 2 short springs on my 58 to soften the ride
isn't the axle above the springs on a 48 3100?
if so use lowering blocks
you may need to c-notch the frame at the same time
shop air compressor timer
