Old 04-20-2015, 06:03 PM   #1
Blanco_53
Transmission problem
I have a 82 gmc swb and haven't had a problem with it but recently I had it parked for 2 weeks and now it's having trouble getting in the garage. Even going over curbs it seems like it doesn't have enough power but in a lower gear I have no problem.
Blanco_53 is offline   Reply With Quote
Old 04-21-2015, 10:33 AM   #2
GRADYS Performance
GRADYS Performance's Avatar
Re: Transmission problem
What transmission do you have? Did you check fluid level?
GRADYS Performance is offline   Reply With Quote
Old 04-21-2015, 12:43 PM   #3
Blanco_53
I believe it has a 350 transmission and yes I have checked the level but may have a leak somewhere ? I drove the truck 7 hours when I bought it no issues .
Old 04-21-2015, 12:58 PM   #4
GRADYS Performance
You can count the pan bolts and look at the shape of the pan to determine the transmission type.
After that you will have to look at the adjustments for tv cable, take off pan and check fluid and filter condition, Check for vacuum line leaks if TH350 with a modulator and take a line pressure test. These should help to determine if the transmission is damaged internally.
Old 04-21-2015, 01:48 PM   #5
Keith Seymore
Keith Seymore's Avatar
Trans pan shapes:
Chevrolet Flint Assembly
1979-1986
1986 - 2019
