Old 04-21-2015, 11:49 AM   #1
chincha805
s10 swap with 3" drop spindles and 4" blocks?
has any one used 3" drop spindles with stock springs and 4" block on a AD S10?
i have read alot of people using 2" drop spindles with 3" block, just wondering if the 3"/4" would be to low.
chincha805 is offline   Reply With Quote
Old 04-21-2015, 12:10 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: s10 swap with 3" drop spindles and 4" blocks?
Who makes a 3" drop spindle for the S10 chassis?
Keith
Convert to disc brakes.
Old 04-21-2015, 12:29 PM   #3
chincha805
I don't know. I just assumed they did. I did a search and can't find an. looks like they do a 2" drop spindle with 1" drop spring for the front.
Old 04-21-2015, 01:05 PM   #4
lolife99
lolife99's Avatar
correct.
Keith
Old 04-21-2015, 01:21 PM   #5
HUSSEY
HUSSEY's Avatar
I have 2 in. drop spindles and 3 in. blocks. Never seen 3" spindles. My 3 in. blocks are at the scrub line so I would stay away from 4 in. blocks.
They sell 4 in. dropped leaves. You can also get dropped springs.
The drop and how low the truck is will also depend on the height the cab is mounted off the frame. I've seen in other builds with the cab ~4 in. off the frame, 2 in. drop spindles, and 3 in. blocks, the truck sits nice:
http://67-72chevytrucks.com/vboard/s...=382481&page=5
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
Old 04-21-2015, 02:33 PM   #6
chincha805
OK, Thanks, i want to go low as possible without bags.
Old 04-21-2015, 04:21 PM   #7
steve aleve
I have just set my cab and fenders on an s10 frame with 2" spindles and 3" blocks. I have set the cab about a half inch off of the frame and the rear of my front fender is about 4" off the ground. I think this will put my running boards about 3.5" off. It also depends on the size rims and tires you are running. I have 15's on all four corners. P235 70 R15 Radials in the rear, P225 70 R15 Radials in the front.
steve aleve is offline   Reply With Quote
