Old 04-21-2015, 09:15 AM   #1
OldChevy61
OldChevy61's Avatar
62 c/10 axle swap
The 62 I just got has the 10 bolt rear end with 6 lug. Is there a newer model 5 lug axle that will fit that rear end . Seems like it would be much easier than having to make a different housing fit the truck. Has anybody done this?
OldChevy61 is offline   Reply With Quote
Old 04-21-2015, 09:34 AM   #2
LVPhotos
LVPhotos's Avatar
Re: 62 c/10 axle swap
I used a 1970. About inch wider. You will have to weld on new perches no matter what.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 04-21-2015, 09:43 AM   #3
53Sparky
53Sparky's Avatar
CaptainFab makes and sells the spring perches you would need. And seemingly an infinite knowledge of our 60-66 trucks. If you have any questions, ask him.
We'll burn that bridge when we get there
My current project: Rust Therapy 62 C10
Numbers 6:24-26
53Sparky is offline   Reply With Quote
Old 04-21-2015, 10:42 AM   #4
OldChevy61
OldChevy61's Avatar
I'm talking about just sliding the axels out of the housing and new axels in,not doing a complete rear swap.
Old 04-21-2015, 10:55 AM   #5
slepysal
slepysal's Avatar
If its the original 62 rear end there are no direct replacement axles.
You might be able to get your axles re welded.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 04-21-2015, 12:40 PM   #6
frankslagoon
if your axles aren't wore out at the bearing surface. then like sleepysal said. have them welded up and redrilled. I think all the 5 lug axles are longer and the spline is different.
frankslagoon is offline   Reply With Quote
Old 04-21-2015, 01:26 PM   #7
OldChevy61
OldChevy61's Avatar
Thanks Guys. Just trying to gather as much info as possible to help decide which way to go with this truck once I get started. One part of me wants to do a lot of upgrades. The other says go all original.lot of $$$$$ to modernize so to speak. Will be a frame off either way, so still a lot of $$$ .
Old 04-22-2015, 01:46 AM   #8
Captainfab
60-66 Nut
There are no 5 lug axles available for the '62 and earlier Eaton HO32. In fact there are not much available in the way of parts for those. Aside from the basic bearings and seals from your local auto parts store, there is only 1 gear set available. That would be 3.38 gears. Unless you are lucky enough to already have those gears, your differential likely has 3.90 gears, which are a little low for comfortable highway driving. One option there is an OD trans. To get your 5 lug axles, you will have to plug and redrill the original axles. As already mentioned, I would only do that as long as the axle bearing surface is in excellent condition.
The '63 to early '70 12 bolts are the same width as your Eaton HO32 but are available in 6 lug only. But 5 lug conversion axles are available. The '71-'82 12 bolts are 1.5" wider and are available in 5 lug. There is plenty of aftermarket parts support for the truck 12 bolt. Any differential you would swap into your truck will need the trailing arm mounts moved or added as well as the panhard bar mount.
Old 04-22-2015, 06:31 AM   #9
OldChevy61
OldChevy61's Avatar
Thank you sir.
