Old 04-22-2015, 08:11 PM   #2
MalibuSSwagon
Re: 4L80 PCM and Wiring Harness Info
If you are using the stock PCM it will control the 4L80E with the correct programming. You just need to either repin the 4L60E connector for the 4L80E or use the factory harness.
MalibuSSwagon is offline   Reply With Quote
